Question about Peg Perego IGED1084 Santa Fe Train
What's wrong: Thomas ride on music is working moves a bit then stops
Hi I got my son this for Christmas and fully charged it, he looked at it for 5 mins and never looked at it again so I never charged it. I have since passed it on and getting told the music works and the train moves a little then stops. Could there be something wrong or does it just need a really good charge? Thank you
Master Axelrod VR
    New Friend:
Hi, Batteries tend to fail on charging if not used for a while- try a really long charge and see - if it still fails to hold a charge - the re-chargable battery will need replacing.
Posted on Dec 07, 2017
4 Related Answers
Anonymous
SOURCE: Peg Perego Thomas Train Track Rider
The red button on the right must be held down for anything to move. It turns the lights on, makes some train noises, then moves forward. If you don't hold the button down, nothing will happen. Note that when the train is underway, the left red button becomes a train whistle. Otherwise, when the train is not running, that left button produces music. Hope this helps.
Posted on Dec 21, 2008
romney2012
  • 156 Answers
SOURCE: Thomas Train
It might need a new wire connection to the motor.
I would contact
http://www.shopjandl.com/
They help me with my ride on toys.
hope this helps
Posted on Jul 22, 2009
Stephen Lam
  • 670 Answers
SOURCE: Peg Perego Thomas the Train Ride-on Music button not working
It could be a bad switch or the music board has a bad contact.
Posted on Dec 24, 2009
adamfjeld
Adam Fjeld
  • 1508 Answers
SOURCE: thomas train shows as fully charged however when
the music is run by three aaa batteries so that will work no matter what, did you reconnect the battery to the vehicle after charging it
Posted on May 04, 2012
My Thomas 6v Ride -On Train works, but VERY slow. It sounds like its really struggling to go. I have TWO fully charged batteries so I know its not the battery. Everything else on it works great...
It sounds to me like your battery needs to be replaced. The batteries lose their ability to hold a full charge after some time (especially if they've sat for a long while without a charge). You can get the battery tested at a trusted shop, but it might be more econimical to just replace the batteries with fresh batteries and see if that solves the problem. New batteries will charge much better and hold the charge much longer.
Sep 23, 2013 | Peg Perego Gaucho Superpower
My sons gator lost reverse, but still had forward 2 gears, then stopped working all together. I fully charged battery and still nothing. It will honk the horn, but wont move forward
horn runs off of a seperate power supply, check the battery nad charger with a multimeter and make sure that its putting out at least 12 volts
Jun 01, 2011 | Peg Perego John Deere Gator HPX Ride on...
I got a alba mpk4065buk for my son for christmas and after christmas died down i tried to install music on it. when you plug it in to the computer it is seen and the lights on the front light up blue...
If it is brand new it will probably take a long time to charge up from the computer. It will need to be fully charged before the screen lights up.
Dec 27, 2017 | EraTech EVR-150 MP3 Player
I have the Peg-perego Battery Operated Thomas the tank engine Ride-on. We bought it in 2006, used it a couple times...put it away bc my son was afraid of it. now my other son wants to ride it. When we...
I would check the battery voltage with a multimeter if possible. Battery should read at least 6 volts. Most likely the battery is too old to take a charge if it’s been sitting unused since 2006. I’d replace the battery first and then go from there.
Oct 07, 2017 | Learning Curve Toys Thomas the Tank Engine...
Thomas train shows as fully charged however when trying to use it, music starts but then a clicking noise and train doesnt move
Jun 25, 2010 | Peg Perego IGED1084 Santa Fe Train
Thomas train charge battery has music and sound effects, but does not move?Does it need a new motor
I would contact
hope this helps
Jul 15, 2009 | Peg Perego IGED1084 Santa Fe Train
Hi
Have you tried keep pressing the right hand button down. When you press the button down and hold the press, then the sounds are finished, the trains starts driving. When you release the button the train stops at once.
May 28, 2009 | Learning Curve Toys Thomas the Tank Engine...
I cannot promise that this is the problem, but this is where mine was broken, and you may be able to fix yours this way.
I was able to remove the plastic around the tender and access the motor. Using alligator clips, I was able to connect the battery directly to the motor, bypassing the circuit board. The motor functioned, therefore the only component that seemed to be defective was the circuit board, located behind the speaker in the engine unit.
As far as I know, the only place to buy a replacement circuit board is from www.tigerimports.com. Search for part number MEVA0024. Cost is around $15 + shipping (around $6 or so).
I should be receiving this part by the end of the week and will report if it fixed the problem.
Thanks for using Fixya. If I didn't help your situation, please DO NOT label this advise as "inappropriate".
Mar 12, 2009 | Toys
Dec 16, 2008 | Peg Perego Vespa Scooter
Nov 21, 2008 | Peg Perego Vespa Scooter
Peg Perego IGED1084 Santa Fe Train Logo
79 people viewed this question
Top Peg Perego Toys Experts
Marvin
Marvin
Lawrence Oravetz
john h
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
