Question about General Electric WCVH6800J Front Load Washer
Error code E01 GE front loader washer - General Electric WCVH6800J Front Load Washer
What do error codes e06 and e01 mean?
E01 and e06 codes - Fixya
www.fixya.com/support/t14040885-e01_e06_codes
Aug 19, 2012 - e01 and e06 codes washer will not do anything other than lock the door. - Whirlpool Duet: WFW94HEXW Laundry : question. ... Error message E06 onWhirlpool. Unplug the machine and wait 10 minutes before restarting it.
Aug 24, 2015 | Maytag Washing Machines
Washer error F06 E01
The error codes F6 E1 for Maytag Maxima 6000 front load washer means that the MCU AND CCU are not communicating. You need to check the wiring and plugs to make sure they have a good connection.
Feb 10, 2015 | Maytag Washing Machines
Whirlpool Front Loader Washer Model WFW94HEXR2 hearing a humming sound at the beginning of a cycle and no water enters the machine. Eventually a E01 F03 error code displays. I power off and then wait for...
You have a bad water inlet and it will need to be replaced. Here is the part to order. To gain access to the valve, disconnect the power cord, remove the top plate and you will see the valve.
Aug 31, 2013 | Whirlpool Washing Machines
Bosch vision error code E01 on washer
error code e01 means the computer thinks the door is open even when it's closed you can repair this using this guide:
Bosch Front Load Washer Error E01
Aug 23, 2013 | Bosch WFVC5440UC Washer
Bosch Nexxt Washer Error Code E01
means that the computer is seeing the door as opened even though it may be closed, you can fix this by following this guide:
Dec 01, 2012 | Bosch Nexxt Premium WFMC6400UC Front Load...
Error code E:01
Hi and welcome to Fixya, The E01 error for your bosch indicates a door lock problem has been detected at the control board. Insure the door is closed tight, turn your breaker off or unplug the washer for a couple of minutes and retry. Let me know what happens, ultimately it may be a faulty lock assembly, a loose wire harness etc. but we'll cross that bridge when we get there...if necessary. I'll watch for you to respond with the result's. Good luck. Macmarkus :)
Jun 07, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
F-02 error code on whirlpool front loader duet
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loader
May 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
General Electric WCVH6800J Front Load Washer Logo
526 people viewed this question
Top General Washing Machines Experts
Michael Thomas
Michael Thomas
Jeffrey Keatley
Level 1 Expert
William Miller
William Miller
Are you a General Washing Machine Expert? Answer questions, earn points and help others
