Hi There
The designation you supply is not recognised by the Gigabyte site, so I suspect there will be another model number on the board.
The link below takes you to a page on their website where you can choose the socket type and chipset of your board and having done that you can get to the download page for the software and drivers you need. http://uk.gigabyte.com/support-downloads/support-downloads.aspx
Good luck
as far as the SATA prob is concerned your mobo supports sata 2 as per the weblink http://support.packardbell.com/uk/item/index.php?i=spec_SeagateTonkaII_Serial&ppn=PB34305801
Either there is a problem with the physical fitting of the processor, or the motherboard is not equipped to handle said processor, even with a bios revision.
Hi
Pentuim D is a processor that has 2 x cpu in one and a core 2 duo has 2 cpu's plus 1 smart core bigger cache
you can only upgrade to a E2140 or E2180 processor on that motherboard
OR replace the board with a newer type
If you want to work the actual speed for the processor of a dual core take the speed for example dual core 1.8 x 2.1 =3.78 GHz
Core 2 Duo 1.8 x 2.4 = 4.32 GHz
looks like that mobo can only suppoport up to 53 mhz front side bus for a celeron d processor wht tht means is tht u can get any cpu tht has the front side bus up to 533mhz with the 775 socket forur motherboard
and forpentium 4 its 800mhz and agian any cpu with up to 800 mhz front side bus and 775
so ur best cpu for tht mobo would be the SL7RR it supports hyperthreading
