Question about Canon PIXMA MX410 - multifunction fax / copier / printer / scanner color
Scan gear error 5 156.61 on my canon pixma 230 how can i fix
My scnner don't work on my canon pixma 230 printer just the error message 5 156.61 appears but I cant find the problem
5 Related Answers
Anonymous
SOURCE: canon printer displays error
CANON
PIXMA MP450
Discharge of the code of the error of the overcrowding of sump - "pampersa"
1. You will turn off printer.
2. retaining button Resume/Cancel (red triangle in the circle) press button POWER - indicator it will catch fire by green color.
3. you will let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which you will let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!
6. you will turn off printer by button POWER.
Posted on Dec 06, 2007
Anonymous
SOURCE: Canon PIXMA MP140 error code E 2
error E 2 => The machine is out of paper. / Paper does not feed.
Reload paper in the Auto Sheet Feeder and press the Black or Color button.
Posted on Mar 02, 2008
Anonymous
SOURCE: Canon Pixma MP130 error 5200
Simple! After saying a prayer, I pulled the power lead from the printer (whilst it was still switched on) then I replaced it. Hey presto! Everything returned to normal!
The moral of this story is: do the simplest things first, rather than uninstalling, re-installing, etc. as I had previously tried to no avail.
Caution: if you do think of uninstalling MP Navigator, consult the Users' Guide - there is a correct order for doing this, otherwise you end up with MP Navigator on board and unable to either uninstall it or re-install from the CD, as I did.
Fortunately, there is still Omnipage and Scangear available which can cope perfectly with all scanning needs.
Posted on Dec 18, 2008
yboyandrei
Francis Mark Arango
  • 828 Answers
SOURCE: Canon PIXMA MP180 All-I-One It shows check printer 5100 erros
error 5100, this error appears and the problem is your cartridge, please double check your cartridge is connect properly and if it still have the errors change another cartridge, a new one...
Posted on Jun 22, 2009
Anonymous
SOURCE: Canon Pixma MP198 error code 2 114 0
i got a same prob..i can't print,scan and copy and the refill warning always appeared..i hv refill the cartridge and i shut it down and try again and again..it's the cartridge prob or the printer prob..?
Posted on Apr 10, 2010
Error 2,156,50 canon mg 2120
I found the solution for 2,156,50 error message, you can read it in the link. It worked at least for my printer (Canon MG3155)
Error code 2 2156 50 on my canon pixma MG2260 printer
Jan 17, 2013 | Canon PIXMA MG2120 Photo All-in-One Inkjet...
Mp navigator 4.3 don't start
On Windows Vista, the following error message may appear while scanning:-
"Cannot communicate with scanner.
Code: 2,155,0 (or Code: 53,3,0)"
In such a case, close the error message and confirm that the cable is connected and the printer is turned on. And then perform a scan over again after a while.
Oct 29, 2011 | Canon Pixma MX360 Printer
Scan gear error code:22500
Hi my canon pixma mp160 is showing scan gear error coad 22500
Mar 13, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Error code:2,114,0
HI
I have Canon PIXMA MP210 printer but problem is that whenever i given comand for print or scan than computer show "Code: 2,114,0" this message therefor printer not print or scan. so please give me solution
Thanking you,
[email protected]
Dec 06, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon Pixma MP600
Canon Error Codes
L5000,5500,7000,8000: To enter service mode Data Registration, #, Ram Clear is under #8 clear
Faxphone 20 ram clear
Turn off the power switch
Turn off the memory protect switch (located on the bottom of the machine)
Turn the power on
Press function # 2 0 start
Turn the power switch off
Turn on the memory protect switch
Fax L770 fuser gear wears out easily under heavy usage. White gear with 2 sets of teeth.
Inkjet models such as the B160 will hold faxes in memory and refuse to print if excess ink has accumulated on the pad under the cartridge's nose. Remove the cartridge and wipe up excess ink with a cotton swab.
Nov 04, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MX410 - multifunction  fax / copier / printer / scanner   color Logo
49 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
