Question about Daewoo DTQ-27U4SC 27" TV
How do i change the input
Changing input
    Sergeant:
  • 148 Answers
The 27" TV uses the same instructions as the 20", and I found the manual for you at the link below. Answering your question directly, here is the section of the instructions about changing input:
Changing the TV's Input Normally, your TV displays the signal coming through the antenna terminal. However, if you've connected another component to your TV(such as a VCR & DVD) using the Video/Audio input,you will want to be able to view the signal from the component.To do this, you will need to switch from the ' TV ' input to the 'AV1-AV3, CVI' Input, as follows. 1 With the TV on, press the MENU button twice, then " Set-Up " menu will appear. 2 Use the WCHV buttons to select " Input ". 3 Press the CVOLB buttons to change the input source from ' TV ' to 'AV1, AV2, AV3, CVI'. 4 Wait 20 seconds, or press DISPLAY button or MENU button to return to normal TV viewing. * CVI means the Component Video Input (Y/ PB/ PR) from the DVD player etc.* Users can also select these input modes with the TV/AV button or the INPUT button on theremote controller. * On the AV1 mode , if you connect the S-VHS jack to your TV, "AV1" is changed to "S-VIDEO".
The link to the manual is below.
Posted on Jun 03, 2014
47" lg 3D tv won't change inputs and only displays "HDMI 3"
Try changing inputs using the touch buttons on the front lower right bezel of the tv.
Feb 12, 2017 | LG Televison & Video
How to source AV Input on remote
Search Results
    How do I change the input on my television? ' FAQ ' Cogeco ...
    https://www.cogeco.ca/.../how-do-i-change-the-input-on-my-tele...
    CogecoClick on the TV button near the top of the remote. Click on the video source button on the bottom left corner of the remote. Using the arrow keys to highlight/select the inputyou want. Some televisions may require pressing the source button multiple times to change the inputs.
    Understanding Inputs - Harmony Support - MyHarmony
    https://support.myharmony.com/.../understanding-different-input-changi...
    Televisions, AV receivers, soundbars and other home electronic devices switch ...Devices with toggle (or cycle) inputs have a single button on their remote that ... In the below example, you would press the Source button to bring up a list of ...
    Changing AV input on TV using Sky remote ' AVForums
    www.avforums.com > ... > Satellite TV, Sky TV & FreeSat
    Changing AV input on TV using Sky remote. Discussion in 'Satellite TV, Sky TV ...VSX-924 LG simplink changing AV source to TV. Posted By djrobmac In AV ...
    Selecting the DVD, VCR, Game Console, HDTV, Camera, or ...
Feb 08, 2016 | Venturer KLV39150 15" Under Cabinet LCD TV...
I need to reset my combination to my mesa safe
This safe was shipped with a factory Master Code of 1-2-3-4-5-6-7-8.
If you changed the Master Code you will need to use the code you changed it to.
Deleting your current User Codes:
Input * - * lock will beep twice
input 6-6-6-# lock will beep twice
Input current Master Code - # lock will beep twice
Input user number - # lock will beep twice (not user code, user number is which user number you want to delete 1,2,3,4 or 5)
Re-input user number - # light stays green for 3 seconds
Example: * - * - 6 - 6 - 6 - # Master Code - # - 5 - # - 5 #
This will delete user 5
Unsuccessful code change: five beeps, repeat the steps.
Changing User Codes: Code length can be 3 to 8 digits long
Input 4 - 4 - 4 - # lock will beep twice
Input Current User Code - # lock will beep twice
Input User Number - #
Input New User Code - # lock will beep twice
Re-input New User Code - # light stays green for 3 seconds
Example: * - * - 3 - 3 - 3 -# - User Code 2 - # - 2 - # -New User Code - # - New User Code - #
That example will change user code 2.
Unsuccessful Code Change: five beeps, repeat the steps.
There are other things you can do with the MSL-500 lock that comes on the MFL-2014E. You can change the master code, activate user codes, change user codes, delete user codes, set single user or dual user modes (dual user modes requires two user codes to be entered each time you want to open the safe, set the time delay.
The Mesa safe company has a website which does have the operating instructions for the MSL-500 electronic lock. A Google search of "Mesa MSL-500 Operating Instructions" would get you there quickly.
Oct 18, 2013 | Mesa Safes MFL2014E Safe Depository Safe...
I cant keep my tv turned on after i pushed the rgb button by mistake it keeps on displaying no signal and then it goes off
Turn on the TV again. You need to change the input from RGB back to cable or HDMI or Component or whatever input you have a source for. If you don't know which one, look at the back of the TV and the wires you've got plugged into it.
If it's 1 round coaxial cable, change the input to Cable.
If it's three wires (red, white, and yellow) change the input to A/V.
If it's 5 multicolored wires, change the input to Component.
If it's an HDMI cable, change input to HDMI.
If you cannot change the input before the TV turns itself off, try unplugging the TV from the wall socket for about 10 seconds, and then plugging it back in. If its still on RGB, you're going to have to either find a way to get faster at switching inputs, or find an RGB cable and something to connect it to your TV. This is a last resort however.
Jun 09, 2011 | Televison & Video
How can I type Japanese o keybord?
Hai ! This is possible : )
Type in Chinese, Japanese, and other character-based languages
To type text on your computer in character-based languages, such as Chinese and Japanese, follow these steps:
[Source: http://windows.microsoft.com/en-us/windows-vista/Type-in-Chinese-Japanese-and-other-character-based-languages]
  1. Add the language as an input language. If you want to use an input method editor (IME), make sure you select it when you add the input language. For more information, see Add an input language.
    You can edit documents in multiple languages by changing the language (the input language) in which you type. Input languages are included with Windows, but you need to add them to your list of languages before you can use them.
    1. Open Regional and Language Options by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Clock, Language, and Region, and then clicking Regional and Language Options.
    2. Click the Keyboards and Languages tab, and then click Change keyboards.
    3. Under Installed services, click Add.
    4. Double-click the language you want to add, double-click the text services you want to add, select the text services options you want to add, and then click OK.
  1. Change your input language to the language you installed. For more information, see Change your input language.
The input language is a setting in Windows that controls the language you use to type information on your computer. Before you can change an input language, you need to add that language to Windows. For more information, see Add an input language.
To change the input language
Click the Input language button on the Language bar, and then click the input language you want to use.
93d5c617-b1ec-4138-a1ff-973e71de80fe.pngLanguage bar gl_ico.png Note
If you don't see the Language bar, right-click the taskbar, point to Toolbars, and then click Language bar.
  1. Change your keyboard layout to the desired layout. For more information, see Change your keyboard layout.
You can customize your keyboard for a specific language or format by changing the keyboard layout. The layout controls which characters appear on the screen when you press the keys on your keyboard. Some input languages have several keyboard layouts; others have only one. For example, you can change your keyboard layout from the English QWERTY format to the English Dvorak format. After you change the layout, the characters on your screen might not correspond to the characters on your keyboard keys.
Before you can change the keyboard layout, you must add the input language and keyboard layout that you want to use to Windows. For more information, see Add an input language.
Hide all expcol_imgs.png To change the keyboard layout
  1. On the Language bar, click the Input language button, and then select an input language.
  2. Click the Keyboard layout button, and then select a keyboard layout.
gl_ico.png Note
expcol_imgs.png To change the keyboard layout on the Welcome screen
On the Welcome screen, click the Keyboard layout button 0c181420-8a93-48b6-82b1-b2dc25fc01b5.png, and then select a keyboard layout.
TIP:
After you are done you can switch between Japanese and English very easily by manually pressing the on screen buttons or using keyboard commands like SHIFT+ALT to switch between Japanese (???) and the Alphabet.
May 04, 2011 | Compaq Keyboard
Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
Apr 06, 2010 | Orion STV2763 27" TV
Can't change FM input mode! Stuck at analog...
Tuner is only analog. As for the Video 1 input you need to go into the menu and change it to the digital port you want to use (optical, coaxial or HDMI) you can set only one input to each digital input port.
Nov 30, 2009 | Sony STR-DE597 Receiver
Need to change input mode to video
on your remote there is a input button if you
have the factory remote.press this and will
change inputs.
Jul 18, 2009 | Televison & Video
Yamaha Receiver loses audio when changing DTV stations
I believe changing stations is triggering the protection on receiver. When you go to another input and back you give time for the protection circuitry to release speakers again. Try muting your receiver before changing channels. Good luck!
Nov 21, 2008 | Yamaha RX-V463 Receiver
No longer can change inputs on tv
mine did the same and i have been told that it is the mother board
Nov 21, 2006 | iLO 2600 Television
Daewoo DTQ-27U4SC 27" TV Logo
545 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Ekse
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
