1. Power of the device.
2. Now,Hold down both volume+ and power button simultaneously, you should get an android on its back opened.
3. Press both volume + or - to open up a small blue text menu.
4. Then use Vol - and Vol + to navigate the Recovery mode.
7.)Select "Factory Data Reset", press power, choose "yes" from the menu then press power again.
Go to Settings -> Storage -> Factory Data Reset.
If that is not an option, then:
1. Power of the device completely.
2. Hold down both volumes and power at the same time. This should bring up an image of an android on its back, opened up.
3. Press both volumes at same time to open up a small blue text menu.
5. Select "Factory Data Reset", press power, choose "yes" from the menu then press power again.
6. Your zeepad should now be reset
Here are the some simple steps to hard reset your ZeePad 7.0:- 1.)First of all,Go to Settings -> Storage -> Factory Data Reset. 2.)Otherwise,Power of the device completely. 3.) Now,Hold down both volumes and power button simultaneously. 4.)After doing this,you should get an android on its back opened up or something. 5.)Now,Press both volumes at same time to open up a small blue text menu. 6.)Then use Vol - and Vol + to navigate the Recovery mode. 7.)Select "Factory Data Reset", press power, choose "yes" from the menu then press power again.
on the right side of the tablet is a very small hole marked reset you will need a toothpick or something small to push the button. This will reset the tablet to the condition it was in when you first bought it, you will have to go to the play store & reinstall any apps you personally downloaded but that should do it!!
Go to www.zeepad.net click on the picture of your device. Download the device driver, loading program, instructions and the firmware for your zeepad. Reinstall the firmware this will update and bring your unit to Like new
