Question about Whirlpool Pearl Navarre 7242 True Bathtub with Back Massage - 103558-100
Gold neck water jet spout has been replaced four times in the past year by different plummers; I called help line and said to heat up---so they heat it up and shove it in the white port---the very next time I get to use it, after 1 minute---the gold neck water jet flies out and water every where. What can I do to permanently fix the problem?
Bill Boyd
    Top Expert:
  • Whirlpool Master
  • 53,816 Answers
Sounds lie you have push in quick connect fittings
if so the the push in hose is the wrong size
otherwise change the fittings to proper olive connections
Posted on Sep 16, 2017
5 Related Answers
Anonymous
  • 25 Answers
SOURCE: Water keeps dripping from spout .....................
usually bc water valve not completely closing . i wud replace it
Posted on Jul 03, 2008
Anonymous
  • 3 Answers
SOURCE: whirlpool gold dishwasher gets stuck at 53 minutes left for an hour
Try "resetting" the control board by running the diagnostic cycle. The cycle completes in 15 minutes.
The details are in the service manual. The manual can be found hidden behind the tow plate (at the very bottom front of the washer).
The diagnostic cycle may tell you the problem. It also helps clear up some of the software gltiches.
It is easy to run the diagnostic cycle.
Just the buttons in the following sequence. The sequence should be complete within 6 sec.
heated dry -> Normal -> heated dry -> Normal
This will trigger diagnostic cycle of 19 intervals. Pay special attention to the intervals 18, 17, 9, 6, 4.
Interval 18 - displays your controller module number (should be letter 'd' followed by number 0 or 1 or 2 or something. Note that down for future reference.
Interval 17 displays 'software generation number' Note that down for future reference.
Then wait until you reach interval 9.  --- clean LED turns on - then an open or shorted thermister is detected.
-- Sanitized LED turns on - then the washer detected greater than 100 deg F temperature
Interval 7
-- Soaking/sensing LED should NOT come on (unless food soil is present).
Interval 4 -- Soaking/sensing LED should come on
Let the cycle complete and then try running the normal wash. Hopefully the possible glitches are cleared by now and you should have no problem.
If this doesn't work, time to call the expert tech.
Posted on Feb 01, 2009
peyton32034
peyton thompson
  • 410 Answers
SOURCE: WATER LINE 90 DEGREE ELBOW LEAKING FRONT LEFT
Did you actually break the elbow? you may be able to cut the tubing back and get a new surface for the elbow to push back into. if not a 5/16" push in connector is what you need you may be able to find this at a water condition store such as culligan.
Posted on Feb 03, 2009
Maytag317
Victor
  • 1136 Answers
SOURCE: Can't change filter without water pouring out
Hi, If you can't shut the valve off to the water source, you will need to shut the water off to your house and change both the filter and the valve to the refrigerator.
When changing the filter, you will get a little water while removing the filter but, not very much. I hope this helps you.
Please let me know if I can assist you further.
Vic
Posted on May 30, 2009
Anonymous
  • 77 Answers
SOURCE: Whirpool Gold Refrigerator Ice Maker not making ice
check your cutoff sensor, it is most likely a rod that will push up when the ice bin gets full, make sure its not stuck in the up position.
Posted on Jun 21, 2009
How do I clean the spout screen in my lavatory faucet. I can't seem to unscrew it. It won't budge. Is it meant to be unscrewed?
Most are screwed on. Most are hand tight but if not and its gold you might want to have a Plummer have a look.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Nov 14, 2014 | Plumbing
No Hot water coming out when single handle on hot water side.Cold water comes out fine. Water in the lines leading to the taps, but no hot water coming out. This is a bathroom faucet Moen single handle.
Cartridge removal is a simple matter of exposing and pulling out the old cartridge. Before getting started, turn off both water valves underneath the sink and allow the water to run until the line is clear. Using a screwdriver, gently pry off the cap on the lever of the faucet handle to expose the cartridge. Remove the U-shaped retaining clip that holds the cartridge in place and pull the cartridge out. If dirt or residue makes removal difficult, use a Moen cartridge puller to assist you. A cartridge puller fits over the cartridge and gives you greater pulling power.
Soak the dirty cartridge in vinegar for four hours and replace.
If cleaning the cartridge does not work, call the Moen Helpline at 1-800-465-6636 or Customer Service at 1-800-465-6130 to order a free replacement. Locate the part number on the cover page of your instruction manual. If you no longer have the manual, look on the underside of the spout.
Feb 08, 2011 | Moen Monticello Single-Handle Kitchen...
When lever on tub spout is pulled up for shower use some hot water still comes out of the tub spout...reducing water pressure and temperature of water coming out of the shower head... Tub spout does NOT...
2 things can be happing here depending on the age of the tub spout. If the spout is more than 5 years old, you may need to replace it. if not that old then you may have a screen filter blockage in the shower head itself. remove the shower head from the shower neck and see if there is anything in the filter. while you have the head removed, try the tub spout again and see if problem continues. this should guide you in the next step to either replace the tub spout or just clean the shower head screen filter. Hope this helps.
Dec 29, 2010 | Cifial 295.604.625.SO Polished Chrome...
My Whirlpool tub works, except when water goes above jets it is leaking for the motor. Local plummer would not fix it. HELP Thank you
you probably have a jet that is broken. Sounds to me like if the water gets above a certain level the water starts to leak then that is what it tends to be. pumps will leak water when they turn on if the seal inside the pump is worn out.
Dec 20, 2010 | Whirlpool Home
We had our hot water tank replaced and now our water flows really slow out of the tap of our tub. Yet the flow is OK from the shower. We have the single handle faucet. It seems you have to pull the little...
It is not uncommon for one or more faucet devices to go haywire immediately after a water heater change out, especially if the cold water line to the water is galvanized metal pipe and is quite old. while this scenario is the most common, it is not the only possibility. Sometimes it's just plain coincidence in the timing of events.
I would remove and replace the #1222 cartridge, inspect it for obvious debris from the heater replacement, briefly turn the hot water supply on to flush out any possible debris in the valve body itself, then reinstall the cartridge. Valve flushing should always be done before any cartridge gets reinstalled.
If the problem persists, the diverter on the tup spout would be my next focus. Again, debris from the heater replacement could (but far less likely) have affected its function. While not as easy to remove and exactly replace, by taking it off...then turning the water on, you will be able to observe the flow difference..With no difference the problem is in the valve and the cartridge should be replaced....with significant flow difference the, replace the tub spout. Be sure to take the tub spout with you, if it's the problem, when you take it to your plumbing supply store so it can be matched to a replacement. There are many tub spouts for many situations.
Search this site for Moen cartridge removal procedures. I have posted numerous solutions.
Nov 09, 2010 | Moen Posi-Temp Single HandleTub And Shower...
Delta RP34357 Traditional Diverter Tub Spout has been leaking around base and/or water running along bottom of spout toward wall from opening; today, whole spout blew off wall when faucet was opened only...
If this spout is less than one year old, I would contact my general contractor to get his plumber over to look at it. Most GC's (general contractors) will warrant their work for one year. If it is not under warranty, you should be able to fix this problem. Spouts do not typically blow off like that, so I am wondering if there is not an underlying circumstance. At any rate, I will assume the best and tell you how to reinstall the spout. There are several variations on spouts, but the one that is most common is a slip connection. Meaning that the spout will slide over a 1/2" copper water line protruding about 3" from the tub. After sliding the spout on, there is an allen screw on the bottom of the spout that snugs up against the copper pipe (again this is the most common type of install). If yours is different, let me know, and I will walk you through other processes. Before sliding the spout back on the copper, use plumber's putty around the opening that the copper is sticking out of. This will help to prevent water from getting behind the tub. Also, after the install; check the spout to make sure there are not any leaks. If no leaks are detected, use a clear silicone tub/shower caulk and go around the faucet. The caulk does not have to be a 1/4" bead to be effective. Run it around the spout, and using a moist towel, go back over the caulk to remove the excess. If you have done it right, you will not even notice the caulk, except for the gaps. Hope this is helpful.
Nov 20, 2009 | Delta RP34357 Traditional Diverter Tub...
Leaking braided water line from under spout LITTLE GOURMET
you will have to get a replacement from the manifacture,, they will send it to you, call them tell them wich one it is hot or cold they may have diffrent threads then again they may be the same,,,can you get the threaded part out of the faucet, you will need an extractor, you can get this at a hardware store, it has a rubber seal so you can only tighten it so much, get it ot try again but be gentle,, one thing I found after doing plumbing for 34 years if you snug it and it leaks you can always snug it some more if you over tighten it you can't do anything but replace it,,,, good luck let me know how it goes
Jun 21, 2009 | Mountain Plumbing Mountain The "Little...
Hi: It is a separate line. If the tube to the ice maker was not clogged with ice itself that is not your problem. The ice maker is thermally proctected and will not make ice unless the freezer is actually at zero degrees F. Not just frozen. The plastics in a freezer will be soft when warm even easily melt, but be hard when at operating temps. Just try setting your freezer colder to see if it kicks in. Give it at least 24 hrs. Don't do the human nature thing and open it every hour to see if it makes ice. You will just dump the cold air out. Listen for the ice to dump into the tray. I hope this helps, Jeff
Jun 21, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
No Water
You may have a problem with a frozen water line inside the freezer door.  There is a heating element that keeps that water line from freezing but it apparently has failed.  It is not serviceable.  The whole door has to be replaced.
Dec 27, 2007 | LG LRSC26940ST 36" Side-by-Side...
Whirlpool Pearl Navarre 7242 True  Bathtub with Back Massage - 103558-100 Logo
2,807 people viewed this question
Top Whirlpool Home Experts
john h
Mike
Andrew Taylor
Andrew Taylor
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
