KitchenAid KSCS25FKSS Side by Side Refrigerator Logo
s
sammy Posted on May 31, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where do I find a Auger Motor and a Splindle?
I have a refrigerator model number is GSL25JFTABS. And I am looking for a Auger Motor and Spindle. Because a tech came out and told me I needed both replaced. I wanted to see the pricing but can't find them anywhere. Could someone post me some links where I could find them?
william rodriguez
Level 3:
  • Master 958 Answers
  • Posted on Jun 01, 2014
william rodriguez
Master
Level 3:
Answers
958
Questions
Helped
169551
Points
2511
John Tripp
Level 3:
  • KitchenAid Master 4,656 Answers
John Tripp
KitchenAid Master
Level 3:
Answers
4656
Questions
Helped
1677623
Points
14883
Auger control rod will not engage with actuator on ice bucket correctly. I have to keep manually moving the rod with my hand. When bucket is removed the actuator seems to operate fine.
Hello friend, thank you for your submission!
From what you have described the auger on your Frigidaire refrigerator is not operating properly when the ice bucket is installed. This could be a possible issue within the ice bucket or motor of the refrigerator. I would be happy to help look up any additional information with the use of your model number. You can locate the model number on your serial tag which is in the fresh food section. Once I have that information I would be happy to assist you further. -Matt
Why doesn't the auger drive motor work?
seems like the motor to turn the auger might be having issues getting power inside the door panel but if your able to move it freely it could mean the motor is burned up or isnt getting power
Apr 21, 2017 • Freezers
Where Is The Defrost Timer Located On My Ge Refrigerator Model GSL25JFTABS
Where is the defrost timer in my General Electric freezer model number PSS26NSTB SS
Gs6nbexrq01
Hello Michael Smith - I am happy to assist you. First, I will need a valid model number (and serial number if you have it) to better address the issue at hand. The serial tag is typically located inside the cabinet, on the right side wall. What exactly is the issue the unit is experiencing? Is the auger motor not working properly or damaged?
Kenmore model number 253.55693400 when I push the ice dispenser tab the motor to push ice is on, but not pushing ice out.
You have an auger type of ice dispenser, so when you say you hear the motor is on, do you mean it is turning the auger? Take out the ice bin and close the door, push the dispense button and then open the door quickly to see if the auger is turning. If is is then dump your ice bin and let it sit out until it is completely defrosted and dry. Reinstall the ice bin and put the lever down. And see if that will clear the problem. The auger motor is not that strong and if you get any ice build up under the auger it will stop working. So defrosting and drying will normally clear it up.
I have afrigidaire professional and ice auger is not turning and Ican,t find model number
Hi.
The auger motor and the solenoid actuating the motor must be tested. The model number is printed on the service tag. To find the service tag see: help finding your model number
If you need parts and diagrams see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
1helpful
Need a replacement splindle for Sears LT3000
The complete spindle is called a mandrel on sears site part number 192870 $47.24. You can also get the housing all by itself and reinstall the shaft and bearings into it part number 187281 $24.60. The shaft is what the blade attaches to and can be purchased separate part number 192872 $17.84. All these parts can be purchased at a local Lawn repair shop for less money just take in these part numbers or your model number with you.
2answers
Ice crusher does not turn
KSCS25FKSS is the model you posted under is this the correct model number.If so the motor should be behind the panel directly behind the ice bin inside the freezer.
1helpful
GE refrigerator model GSS22 WGMD ice maker motor
If you cant manually turn your auger motor, it may be bad. Does it dispense solid ice or no ice at all? Another thing may be your control panel. That could be bad too, it's the one sending juice to both your solenoid and auger motor.
Top KitchenAid Refrigerators Experts
vince
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
