SOURCE: craftsman mower with 26hp kohler smokes when i cut on hill, why?
what happens is the oil gets into the valves which will come out the exhaust when on level ground after a side to side or going straight down because the valve's are in the front of engine which is pointing to the front of mower you wont hurt the engine if it does that i would just check the oil often to make sure it doesn't run out
SOURCE: DGS 6500 w/26hp Kohler Courage surging
i HAD SIMILAR ISSUES WITH MY 2500 SERIES CUB CADET....IT WAS THE CARB.....REPLACED, AND ALL HAS BEEN WELL...THINK IT WAS APROX 200.00
SOURCE: 27 hp kohler v-twin ohv backfires, and @
SOUNDS LIKE IT HAS BAD GAS AND THE VALVES NEED RE SET YOU MAY WANT TO FLUSH YOUR FULE AND CLEAN OUT THE CARB LET ME KNOW IF THIS HELPS
SOURCE: can i use a synthetic oil in a 26hp kohler engine
If it helps, I have the same tractor and I have been using synthetic mobil 1 for 4 years. No problems, and the oil is always golden brown without changing... Seems to work great.
SOURCE: 26hp kohler craftsman wont start. just quit
hey i think there is a 20a fuse open which would describe your problem. on the discharge side there is a auto style 20a fuse closest to the steering cowl the bracket that hold the starter relay is were the fuse is. you cant see the fuse but on the bottom of the bracket you will see a little clip pull that clip down and the fuse is attached to that. if the fuse is open that why it wont start. thats were im at now on my problem now the fun part whats causing it to open. hope this helped
Testimonial: "thanks! that was it!!!"
