Question about Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV
Lso Replaced Fboard where the power cable or code is connect to board. replug all g1 board and g2 board, Replace all running lamp to now. I do not know what to do. Last chance g2 board replug it back and Iforget I can fix it.I give some one to repair tv. almost 4 parts replaced g1 board g2 board F board and power code. If I got power I can do something. last try rewireing again let see what happen. Thanks all of the person to help me. I appreciate all of you. I learn with you all time.
Posted by Harshad Patel on
5 Related Answers
Anonymous
  • 105 Answers
SOURCE: Sony Grand WEGA KDF-60XS955
the g1 board is your issue. 6 blinks means there is no or low b+ coming from the g1 board.
Posted on Oct 12, 2007
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: power supply block/lamp issues
Try cleaning the air filter I have seen the same symptons as your describing, and cleaning the air filter corrected the problem.
Posted on Feb 02, 2008
Anonymous
  • 8 Answers
SOURCE: KDP-51WS550 with 10 red led blinks upon power-up
I have a power supply board(g) a audio board and video board and all other boards that im looking to sell they are all good might sell cheap cal me at 573-433-1925
Posted on Oct 19, 2008
Raditronic
Radames Pagan
  • 196 Answers
SOURCE: My 42e2000 just said
I recomend chnge the lamp now to avoid ballast problem after.and remember reset the lamp timer after change.for reset lamp timer press menu in the remote control ----setup------in the color adjust side find lamp reset ----a change a new lamp question appear--push yes and ok.
Posted on Apr 20, 2010
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: tv won't turn on 4 blinking led
Red led blinks 4 times is an error code that shows that fan is not running in tv, check fans connections and make sure all are plugged properly.
Thanks.
Posted on Jul 28, 2010
I have this sony tv model no.KDL 46 VE5 no power at all.what could be the problem?
There's a fuse on the power supply board if not blown change the power board I found one for 8 dollars on eBay.
May 30, 2014 | Sony Grand WEGA KDF-55XS955 55" Rear...
Tip
SONY GRAND WEGA ERROR CODES AND WHAT THAY ARE
Lamp cover error 3 times - Lamp cover is not fastened securely - No picture/No sound
Fan error 4 times
- Fan1-4 Power is not supplied.(G2 board)
- Fan connector is not seated securely
- Fan caught wires or harnesses
Temp error 4 times
- Internal temperature is too high
- IIC-E line connector is not seated properly
(WE:H3 board, WF/XS:H4 board)
Lamp driver error 5 times - Lamp driver defect - No picture/No sound
Low B error 6 times -No "DD 6V " output (G1 board) - No picture/No sound
Audio error 7 times
- Short-circuit of Audio power supply line
(KD board, G1 board)
- Blowout of a fuse
(F4702,F4703,F4704 on KD board)
- IC failure
(IC4703,IC4708,IC4710 on KD board)
D-OVP error 8 times
- Overvoltage of +3.3V or +2.5V
(A board, B board)
ATSC-OVP error 10 times
-No "DTL MODULE 5V " output
(G1 board, G2 board)
Lamp error LAMP-LED is ON. - Lamp is dead - No picture/No sound
on Apr 13, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
SONY KDF-60XBR950
The six blinks should have been the G1 board, double check your wiring and the check to make sure you have the 17V coming from the G1 board. If the problem has not changed it is possible you got a bad board.
May 24, 2014 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony KDF 42WE655 Red lamp flashes 10 times what error code is this?
The ten blinks indicate that you do not have the 5 volt output from your DTL module on either board one or board two.
Oct 18, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
Hi again
yes 3x its lamp cover no doubt. ballast supply will give different error on this unit. this should help hdtv man
Diagnostic Item
Description
Number of times
STANDBY or LAMP LED
lamp flashes
Probable Cause Detected Symptoms
Fan error 4 times
Temp error 4 times
Audio error 7 times
- Blowout of a fuse
- IC failure
D-OVP error 8 times
(A board, B board)
Jul 01, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Standby light flashes 5 times
That was for a different model sony have different codes for different Chassis if your model is KF42WE610 an error code of 5 blinks is a lamp error.
Lamp driver error 5 times - Lamp driver is faulty. No sound or picture will be the symptom. Replace lamp driver.
May 23, 2008 | Sony Grand WEGA KF42WE610 42" Rear...
Oct 08, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony Wega 42" LCD HDTV
I've been trying to find th thermal fuse on a 42we655 for like 3 weeks...It's not under the lamp...Any one know where it is?
Thanks
Aug 31, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
No display
as your power supply is ok check hor. section if it becomes ok you will get voltage on g1 &g2.
Aug 16, 2006 | Philips SoHo 105E 15" CRT Monitor
Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
