Question about Smeg F170 Pyrolytic Stainless Steel Electric Single Oven
Neff pyrolytic setting doesnt accept level setting-remains at 0 & bleeps but nothing in oven?
Oven is B 44720.GB
Can anyone tell me if my Neff B1451 is a 13a oven or not.
if its a single not double oven and is not a pyrolytic cleaning system it will work on a 13 amp supply.
Jan 02, 2017 • Neff Ovens
tip
If the door is locked shut after self cleaning
- Let the over cool down - unplug at the mains and leave it unplugged for a good minute or so - reset the clock The door may well open now. It happened to me today !
I have burnt on food (sugar) in my Miele pyrolytic oven. How do I get it off? Will using the pyrolytic process just make this worse?
Ammonia works really good to remove burnt on food. For inside the oven put a small bowl of ammonia on the rack, close the oven door & let sit overnight. The fumes will work overnight.
Dec 01, 2017 • Ovens
Power supply
it doesnt come with a cable it has to have its own 25 amp cable from your consumer unit or previous oven installation.
Neff B4562
Engineer is a solution.
The other solution is;
Switch 3 times between rotisserie and pyrolysis or bread baking setting and pyrolysis.
As acknowledgement the displays are actuated.
At each change of operating modes switch immediately stops the current test step and the next step of the test enabled. The oven light should according to the mode ON or OFF; that is, at pyrolysis OFF otherwise ON.
Jul 01, 2012 • Ovens
7helpful
Pyrolytic cleaning won't start. Neff B15P42.0 GB
you have to remove the shelf supports (left and right) as well as the shelves. The manual tells you about the shelves but not the supports. I only found out as someone wrote the answer on another website
11helpful
Neff B4562 Pyrolytic Cleaning Not Working
You need to remove the rack side supports too. Its not clear in the book as it just says shelves and racks but everything needs to come out the oven.
1helpful
What connection do you require for eye level electric double oven
You need a 45amp circuit for this double oven, under no circumstances , try to run it off a 13 amp circuit.
Plz rate my solution.
Thankyou.
Smeg F170 Pyrolytic Stainless Steel Electric Single Oven Logo
Top Smeg Ovens Experts
Paul Bade
Dennis Boxerman
Are you a Smeg Oven Expert? Answer questions, earn points and help others
