Question about Sharp MX-2700N Color Copier
Sharp MX-2700N Clear U1-01 error code - Sharp MX-2700N Color Copier
5 Related Answers
Anonymous
  • 24 Answers
SOURCE: error code h4-01
P * C * enter sim 14 press copy key then CA. Machine should reboot. if problem re-occurs your thermostat in the fuser has tripped
Posted on Dec 01, 2008
Anonymous
  • 148 Answers
SOURCE: sharp mx 2700n how to go SP mode and i get error code h5.01
Use SIM14 to
cancel the trouble.
Entering the simulation mode
1) Copy mode key ON → Program key ON → Asterisk (*) key
ON → CLEAR key ON → Asterisk (*) key ON → Ready for input of a main code of simulation
enter 14
accpet yes clear..
machine should restart.
You may have to have a tech look into why this is jamming...
Hope that helps
Lbcoaster
Posted on Dec 28, 2008
MIAN
  • 87 Answers
SOURCE: call for service: code U2-05
i think that u2 shows some memory or eeprom problem just reset it .press clear key,exposure mode key,clear key,exposure mode key,press all these key in sequence and quickly.display will go dead now press 16 then start key.code will bi removed .mian jee
Posted on Jan 21, 2009
Anonymous
  • 143 Answers
SOURCE: Sharp MX-2700N - Error Code - 'Call for Service E7 - 05'
E7 is only part of the code. It could be a hard drive problem, memory problem, laser problem, or a loose connection on one of the boards.
Posted on Aug 01, 2009
rezazadeh
abbas rezazadeh
  • 328 Answers
SOURCE: Sharp MX-2700N how can I clear maintenace code CA?
enter code 20-1 start
Posted on May 27, 2010
Erro na sharp mx 3100n U2-80
On the control Panel, press the keys #*C* (pound, star,clear,star)to enter test mode. Enter number 16 and press the copy button. On the touch screen press "execute" and "yes". Press CA to reboot. The error code should clear.
Aug 03, 2012 | Sharp MX-2700N Color Copier
Error code u2-10 on a sharp mx2700n photocopier
U2-10 SRAM user authentication index check sum error. I know, gibberrish right? To clear this error, put the machine in "simulation mode" by pressing "c" "*" "p" "*". then type 16, press the copy button, then press "execute" then press "yes". Hit the "ca" button to go back to ready. This should clear the error code. If the code returns, then the PCU PWB board needs to be replaced. I hope this helps.
Jan 27, 2011 | Sharp MX-2700N Color Copier
My error code u2-10
in order press * # C # then enter the number 16 and execute the function.
that should clear any U2 code
I have a sharp copier MX2700N with an error code of FK1. What do I need to do to fix it?
fuser count has reached 200,000 copies. hit P*C* then 24, start, then 4 start. select Fuser Unit and Fuser Acum Day then execute at bottom then yes. Hit CA button. copier should reboot and clear code.
Apr 17, 2009 | Sharp MX-2700N Color Copier
Call for service: code U2-05
Jan 16, 2009 | Sharp MX-2700N Color Copier
Sharp mx 2700n how to go SP mode and i get error code h5.01 how i solve this problem
Use SIM14 to
cancel the trouble.
enter 14
accpet yes clear..
Hope that helps
Lbcoaster
Dec 23, 2008 | Sharp MX-2700N Color Copier
Error code h4-01
Dec 01, 2008 | Sharp MX-2700N Color Copier
Sharp MX-2700N Color Copier Logo
411 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
