AudioTrak AT-2300P Amplifier Logo
Question about AudioTrak AT-2300P Amplifier
How do I get the amp to go off LOCK mode?
Audio Service Clinic
  • AudioTrak Master
  • 924 Answers
I assume it's in Protect Mode, as I'm not familiar with a lock down mode. One of your amplifiers, is probably damaged, so the unit won't switch on until the damaged is fixed. If you need more information, or would like to inquire about a repair, please visit my website at audioserviceclinic.com.You may contact me there. Thank you.
Posted on Dec 06, 2014
How do I reset keyless door entry that is in lock out mode
Viper Keyless Entry Systems
https://www.viper.com/car/keylessentry/
Viper is the industry leader in keyless entry systems. Add the convenience of keylessentry to virtually any vehicle - even vehicles without power door locks!
Alarms, Remote Car Starters, Keyless Entry & Locks - JC ...
www.jcwhitney.com > Audio, Video & Electronics
20 out of 32 products in Alarms, Remote Car Starters, Keyless Entry & Locks ..... ofKeyless Entry & Car Alarms allow you to lock and unlock power door locks.
How to program your keyless entry keypad - Ford Ownerhttps://owner.ford.com/.../locks.../how-to-program...Ford Motor CompanyDiscover how to lock and unlock your doors and how to program memory settings that will adjust seats & mirrors for each driver.SecuriCode™ Keyless Entry Keypad - Ford Ownerowner.ford.com/.../locks.../securicode-keyless-entr...Ford Motor CompanyLearn how to set a 5 digit SecuriCode on the Ford keyless entry keypad. ... Sign out. Register/Sign In · Your Vehicle. Service & Maintenance. Service & .... vehicle's SecuriCode keypad to lock and unlock your doors without having to use a key. ... Thekeypad will go into an anti-scan mode if you enter the wrong code seven ...How Programming Your Keyless Entry Can Make ... - Ford Life
1helpful
Poor reception with Alpine cda 7892
I found the manual at Alpine.com.http://vault.alpine-usa.com/products/documents/OM_CDA-7892.PDF
3helpful
Hatch back will not open
With key in hand,hit power door lock switch to lock. Raise release handle & lower. Hit power door lock unlock raise & lower handle. May take a couple times is stuck in limbo between lock & unlock mode.
How to I reset my keyless 2005 toyota prius? I recently brought my car to a collision shop to change my driver's side door. They told me they unplug the battery cable. In doing this, now my keyless does...
KEYLESS REMOTE PROGRAMMING
1- Driver's door open & unlocked. Key out of ignition
2- Insert & remove key 2 times within 5 seconds
3- Close & open drivers door twice within 40 seconds
4- Insert key into ignition & remove
5- Close & open drivers door twice within 40 seconds
6- Insert key into ignition
7- Close the door
8- Turn ignition switch from "LOCK" to "ON" & back to "LOCK"
- ONCE for ADD mode
- TWICE for REWRITE mode
9- Remove the key from ignition
10- To confirm your mode selection, the power locks will now cycle "lock" to
"unlock" a number of times corresponding to your key cycles in step 8
11- Within 40 seconds of confirmation
- Press both transmitter Lock & Ulock buttons simultaneously
- Within 3 seconds press transmitter Lock button for more than 1 second
- If successful, the power locks will cycle once (twice indicates
transmitter problems)
- Repeat step 11 for additional remotes
12- Open door to exit programming.
How to start oven in PROPANE STOVE
Print the following infore for future ref if you wish. How it works is simple tage a look at it in Motion
Component Test Procedure Results
Electronic
range control
F1−1 –Upper Oven >650°F with door unlocked.............................
F1−2 –Lower Oven >650°F with door unlocked.............................
F1−3 –Upper Oven >950°F with door locked.................................
F1−4 –Lower Oven >950°F with door locked.................................
F1−7 –Membrane switch is not responding ...................................
F3−1 –Upper sensor is shorted at (< 100 ω) or
open at (>5 K ω) ...............................................................
F3−2 –Lower sensor is shorted at (< 100 ω) or
Check actual upper oven temperature,
if > 650°F check sensor.
Check actual lower oven temperature,
if > 950°F check sensor.
Check membrane switch for connection or damage.
Check upper sensor, harness, and connections
Engineering
Test Mode
Press BAKE pad.
Enter 100°F using the number pads.
Immediately push and hold BAKE pad for appropriate oven
approximately 3 seconds.
This mode can also be entered by pressing the hidden pad
for 3 second located to the left of the lower oven light pad.
Used to view the actual oven temperature for both ovens at all
times, even when an oven function is active.
This mode will also display the current fault code for 5
seconds in the time digits.
Fault codes
accessed
through
Engineering
Test Mode
F0−0 –No fault .................................................................
F1−5 –Upper hardware failure within control ....................
F1−6 –Lower hardware failure within control.....................
F1−8 –Shorted key in membrane switch ..........................
F1−9 –Internal communication errors within control .........
F1−A –Upper latch switches ............................................
F1−B –Lower latch switches.............................................
F1−C –Upper door switch.................................................
F1−D –Lower door switch.................................................
F1−E –Sensor input not calibrated ...................................
F1−H –EEPROM error .....................................................
F1−L –Temp in ovens are the same for long period .........
F1−N –Internal voltage on control not working .................
F9−1 –Upper lock switch is not correct.............................
F9−2 –Upper unlock switch is not correct.........................
F9−3 –Control does not see upper door lock....................
F9−4 –Lower lock switch is not correct.............................
F9−5 –Lower unlock switch is not correct.........................
F9−6 – Control does not see lower door lock ...................
EE –Control cannot read E-PROM. Unit will shut down.
Default from factory
Replace control
Replace control
Check membrane connection
Replace control
Check latch wire harness
Check lock wire harness
Verify sensor is operating properly
Replace control
Replace control
Check lock wire harness, and lock switch
Disconnect power for 60 seconds. If EE reappears, replace ERC
Test Mode This mode must be activated within the first 5 minutes of
power up.
Press BROIL and CANCEL pad for approximately 3 seconds.
If oven temperature is greater than 400°F, the Test Mode
cannot be activated or will abort if active.
Press and hold individual pads for 4 seconds to activate.
Display will have dashes in all segments to indicate the mode is
active.
Upper Bake: Energizes upper bake element
Lower Bake: Energizes lower bake element
Upper Broil: Energizes upper broil element
Convection Bake: Energizes convection fan
Upper Oven Light: Energizes upper oven light
Lower Oven Light: Energizes lower oven light
Upper Clean: Energizes upper motorized door lock
Lower Clean: Energizes lower motorized door lock
Stop Time: Energizes Beeper
Cook Time: Displays error codes
Timer 1: Energizes ROM version
Timer 2: Energizes EEPROM version
Keep Warm: Cooling Fan
Clock: All display segments light
If functions do not perform as specified, replace ERC
Oven
temperature
adjustment
Push BAKE pad.
Enter 550°F using the number pads.
To decrease or increase oven temperature. Push AUTO SET
pad until negative or positive numbers appear. Oven can be
adjusted from -35° to +35° (-37.2° to + 1.6° C) in 5° F (2.7° C).
To avoid over adjusting oven move temperature -5° each time.
Push OVEN CANCEL button.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
The amp is on lock mode and i do not know how to take it off
Hello, Could you please specify what type of clarion amp you have and what happend prior to the problem? I don't know what you mean by lock mode unless it has some security feature or you mean it's in protect mode. If it's in protect mode more thanlikely you have power supply mosfets shorted or output transistors shorted. If all wiring and speakers are good and your head unit. Let me know.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mark_b53a7494531bf96d
My motorola L7 is lock i dnt have the lock/security code
just download "Motokit "software from "modmymoto.com"& install it in ur PC.Select Data/fax mode in usb setting of ur mobile.
then open the MOtokit software & connect ur phone..Software will automatically detect ur phone.
then of top left side of the software select " mobile" & then"info"..it will give u the Unlock code & security code of ur mobile...
vote for me...
Frigidaire, Gas Oven Door
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&^%$#
2answers
On/off button for Zen
Take it apart. Just google how to do it, i found a post with pictures and took mine apart without much trouble (just had to buy a $5 small screwdriver kit at radioshack). the switch for the lock is actually a metal piece that is moved by that **** piece of plastic. You can move the switch easily to where you want it and put the plastic piece in the correct position. -Stoney
Top AudioTrak Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an AudioTrak Audio Player and Recorder Expert? Answer questions, earn points and help others
