Hpw to change font type & size in tally 7.2
SOURCE: I'm using tally 7.2, while printing cheque font
to increase the font size in the printing cheque is just simple go on to (or) press F!! key on the cheque printing option will available on there on the give yes . and then some kind of list will available on there on the list read the sentence one by one the font increasing size is available on there give the correct font size as a number for example (60)
SOURCE: how i can increase the font size in tally ? kindly help.
Go to display properties then go to setting and then advance and change the dpi setting from 96 to 120.
SOURCE: We have purchased Tally DASCOM
The user guide which you can download here
http://support.dascomeurope.com/index.php?option=com_docman&task=cat_view&gid=250&Itemid=48&lang=en
will guide you through the menu settings.
There is an Utility in your Windows.
If you insist i show you but it may be risky Overriding your Original Fonts..
Press WinKey + R it will start Run.
Enter "EUDCEDIT" w/o ' " ' and press enter an Hidden Windows Font Utility will appear.
Select the Fonts you want and override it to "Times New Roman"
All the Fonts in Tally uses Default System Fonts.
GOODLUCK
