Acer A210 Tablet broken screen and digitizer
You dont need to as the screen/digitizer is all in one, basically there are only 3 parts to most of the smaller tablets, mainboard display module & the battery, since you are replacing both make sure that it is a whole module, but you really need a service guide to be able to do this, unfortunately , i cannot tell you where to to get one, but i am sure A210 service guide which is what we at Acer called them may bring a reward.
SOURCE: Where can I find my
Your tablet should not have an SSID. The SSID is the wireless network it needs to connect to. Input yours alog with the password (if applicable) and the tablet should connect.
SOURCE: serial number and snid number for an acer iconia
If you can see the screen partially you can get the code SN and SNID by the following route
Comment back if you can't get it this way.
SOURCE: acer iconia a500 tablet shuts itself off
This might sound a little stupid, but 1 is it plugged in when you put it sleep mode, and when u open the screen do you physically have to turn it back on. Sometimes when you put a computer in "sleep mode" and its not plugged in you lose power slowly
SOURCE: acer iconia is turning off when unplugged on full battery
There are two possible problems:
1. Software (Video Driver)
2. Battery
With regards to the software issue, you just need to update the video firmware or driver. Chances are, your acer is programmed to power savings mode when it's removed from the plug and when it changes the setting to power saving mode, the driver cannot support it because it's outdated that's why it goes off.
2nd Possible reason is your battery going dead. If that's the case, then you need to replace the battery.
I hope this helps.
Carlo
