Question about LG LFD25860
Lg electrocool fridge do I press vacation or quick freeze
5 Related Answers
Anonymous
  • 340 Answers
SOURCE: my fridge won't cool down or freeze
Your condenser is likely dirty clean it. the compressor could be tripped out on over load (to hot) unplug the fridge a couple hours should do it . plug it back in make sure the thermostat is on and set correctly if that does not work you will need service. Tom
Posted on Jun 17, 2009
Anonymous
SOURCE: LG GR-292R freezer works/fridge does not.
well i have the exact same refrigerator but opposite problem.... the freezer works but the entire refridgerator is a freezer....why is the fridge part freezing everything. This appeared to happen after the power went out and the entire fridge is a freezer now.
Posted on Dec 18, 2009
jgwhomeequip
Jeremy Reddick
  • 1902 Answers
SOURCE: How can I switch the door from left opening to
Look at the top and bottom of the door. There should be two holes near the edge. If there is then you just remove the hinges by the screws and place them on the other side of the fridge and flip the door over. At that point your shelves should be able to be flipped also. But if the manual does not say anything then your doors may not be able to be switched
Posted on Jan 02, 2010
Anonymous
SOURCE: i have electrocool LG MOdel# GR-382R ser#
I have the same problem.It seems that the gasket around the freezer door and fridge door are no longer tightly adhering to the fridge therefore allowing the cool air from the freezer to continiuously entering the fridge storage and making evreything freeze up. I am trying to find out if I can purchase new gaskets and install them myself.
Any recommendation on where to find these and how to install them?
Thanks.
Posted on Jan 07, 2011
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: The motor starts, the fan
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 01, 2011
I have LG Electrocool GR-252SQ(Double door).the freezer is very cool but the lower fridge section is not getting cool.Plz guide.
i have same fridge and my problem is that the water from freezer is not going out pf the fridge, instead it comes down to fridge section through condensation
Mar 24, 2013 | Refrigerators
How to set temperature on GE Profile PSS26NGPA WW?
Press and hold temp up button then press quick freeze button at the same time, your temp settings will be displayed on display for fridge and freezer, fridge temp is + and freezer -, cycle by pressing quick freeze, set temps by up and down temp buttons, once done, push vacation button. your temps are now set, turn the unit off for 2 mins the turn on. reaction is now set and normal. regards Russ
Jul 03, 2012 | GE Refrigerators
I NEED TO SWOP THE FRIDGE AND FREEZER DOORS OF MY LG ELECTROCOOL REFRIGIRATOR TO OPEN FROM RIGHT TO LEFT BUT CAN'T FIND THE INSTRUCTIONS MANUAL. WHERE CAN I DOWNLOAD A MANUAL?
Hi there, you don't state the model number in your post but if you go to this link
http://www.lg.com/us/support/product/support-product.jsp and select the help by chat icon on the top left I am sure you will be able to get LG to email you a copy.
May 04, 2011 | Refrigerators
How can I switch the door from left opening to right opening on an LG electrocool (top) fridge (bottom) freezer? The user manual says nothing about it.
Jan 02, 2010 | LG (LRBC22522ST) Stainless Steel
I have electrocool LG MOdel# GR-382R ser# 206MR17803. my bottom fridge cooler area is freezing up.
Thanks.
Jun 22, 2009 | LG Refrigerators
My fridge won't cool down or freeze
Jun 17, 2009 | LG LFD25860
Mar 02, 2009 | LG LFD25860
LG LFD25860 Logo
107 people viewed this question
Top LG Refrigerators Experts
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
