Question about Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV
Mr. Peter I changed fuse 6.3 amp 125v from f board 6amp 125v from radio shake. is that make any difference.
Posted by Harshad Patel on
  • Peter Lesperance Jun 14, 2014
    Hi Harshad Patel, That would be fine do you know if the fuse was blown or did you just change it to see if it would work?
    I don't think I Can help I suspected it would be the fuse many people don't even think about changing the internal fuse becasue they lack the knowledge of them being there.
    There must be something more complex I would suggest finding a tv repair center that will give you a free estimate on repairing it.
Bhabotosh Chakraborty
    New Friend:
  • 138 Answers
You need to put fuse 6.3 amp to 6amp with same 125v if fuse not match or it will give problem
Posted on May 30, 2014
6 amp power board fuse blow when power button pressed.
That is usually caused by shorted output transistors. What brand/model do you have?
Apr 29, 2013 | Audio Players & Recorders
If i put a 6.3A 250 Fuse in a receiver asking for 6.3A 125V will it damage the receiver
no it wont --in all likliehood your amp is shorted however ,and the fuse will blow again ..its rare that a 6amp fuse blows w/o an internal short causing it
Sep 03, 2010 | Audio Players & Recorders
ISymphony M110 blows fuse.
there is an 022 farad cap right under the f901 f 904 f907 f905 6amp rectifier on the main board if short will blow supply board fuse first before it blows the 4 amp fusses on the main board. replace as needed.
Jan 09, 2009 | MediaGear SongBank MP3 Player
RCA HDTV R52WH74YX61 blown fuse
there are 3 small red rectangular shape objects to the right of the flyback transformer these are fuses the fl231 most time goes bad .fl231 is the location number under the green circuit board. the location number can also be wriitten on top(brown side of the cicuit board)
you may have to put back the .6a you took out was it ok?
TRITRONIC ELECTRONICS sell parts . cathray 416 241 1106 sells also
Nov 22, 2008 | Televison & Video
Tv shutting of after 1 min then its on for 5 min then
Fuse, board-mounted, 4a mini AGC glass, 125v.
4-pack at Radio shack runs $4. USD.
Jul 29, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
6.3a slow-blow 125v fuse
Hi, If the fuse physically fits into your unit then it will work. However- - - WARNING! Although 6.3 amps on a 250v fuse will allow the current to flow it will not afford you the circuit protection you require for a 125v circuit. If the circuit develops a fault then there is a danger that you burn out the circuit before the fuse. As you have already blown one fuse I would suggest tracking down the fault before you do any thing else.
The Scrivener.
Oct 12, 2017 | Pioneer VSX-D458 Receiver
I can't find a 6.3 125v fuse
If you look on the board that the fuse sits on you will see printed it states 6amp 125 Volt / 3amp 250Volt. This means that you can use either one. I think that is why the fuse states E.6.3 125Volt... I think it means either 6 amp (125 Volt) or 3 amp (250 volt). I noticed on the back of a fuse package that I bought that it stated these were interchangable so I put two and two together.
Jan 11, 2008 | Panasonic CT-36SX12 36" TV
It will work, the amp rating is most important, 125v / 250v does
not matter.......note: if you blow the fuse again, the TV will
need service.................T.
Dec 08, 2007 | Panasonic CT-36SX12 36" TV
6.3 slow-blow fuse
Important parameter is 6.3 amp slow-blow,voltage rating = 125v
or 250v OK, No Worries.............................T,
Open Questions:
See all Sony Grand WEGA KDF-60XBR950 60" Rear Projection Questions
Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Nasir Muhammad
Nasir Muhammad
Demonic-2011
Demonic-2011
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
