Cell Phones Logo
i
ibo zed Posted on May 30, 2014
What is the lock code of my phone - Cell Phones
Philip Lyman
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on May 30, 2014
Philip Lyman
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
358
Points
If you have an iPhone (Apple), try "Utilities," then "settings," then "passcode." When you arrive at "passcode," you will have various choices, such as turn passcode on, change passcode, require passcode, etc. Good luck.
3helpful
How unlock my phone
What kind of phone lock code do you need?Security lock or network lock
Security lock means try default codes like 12345,00000
If it's network lock,you can unlock your phone by network unlock code.If you need an unlock code visit
WickedUnlock.com
2helpful
3answers
I have forgotten my unlock code to lg revere
This is copied directly from the manual - check out #5 at the bottom.
Hope it helps!
7.7 Security
The Security menu allows you to
secure the phone electronically.
1. Open the flip and press
[MENU]
2. Press Settings & Tools.
3. Press Phone Settings.
4. Press Security.
5. Enter the four-digit lock code.
The lock code is the last 4 digits
of your mobile phone number if
it is set. The lock code is the last
4 digits of your MEID if your
mobile phone number is not set.
6helpful
2answers
Dont know the lock code
which lock code, sim lock code ,phone lock code ,network lock code , privacy lock code
How do you set a passcode for a Sony ericsson j108a so that only I can use my phone
You can stop unauthorized use of your J108a phone by activating phone lock protection.
After activating, you will be asked to enter your phone lock code every time you restart the phone.
The default phone lock code is 0000 (zero-zero-zero-zero). It is recommended that you change this to any four-to-eight-digit personal code.
Note: It is important that you remember your new code. If you forget it, you need to take your phone
to your local Sony Ericsson retailer.
To activate the phone lock:
1. Select Menu > Settings > General > PIN codes > Phone protection > Protection.
2. Select 'On' if you want to enter a lock code every time you start the phone, or select 'Automatic' if you want the code to be entered only when the phone restarts after a new SIM card is inserted.
3. Enter the phone lock code (0000 by default) and select OK.
To unlock the phone:
• When 'Phone locked' appears, enter your phone lock code and select OK.
To change the phone lock code:
1. Select Menu > Settings > General > PIN codes > Phone protection > Change code.
2. Enter the old code and select OK.
3. Enter the new code and select OK.
4. Repeat the code and select OK.
This solution was taken from Sony Ericsson J108a user guide which can be downloaded at:
http://www.sonyericsson.com/cws/download/1/835/750/1284993225/J108i-J108a__UG_EN_1241-2576_1.pdf
76helpful
9answers
Micromax i am forgotted my phone lock code
Micromax q75 phone lock ? : Solution: If you have not changed the default phone lock code for your micromax q75 phone. Then use "0000"(four zeros is the default code) and press the home button(top left most button and not the green sim 1 button). If you press the green button it will say " Emergency calls only" it means you are clicking wrong button. hope this helps you.
Please help me sony ericsson k770i phone lock code
The phone lock code protects your phone against unauthorized use if it is stolen and the SIM card is exchanged. To be able to switch the phone on, you need to enter the four-digit phone lock code. The Sony Ericsson default phone lock code is '0000', but you can change this to any 4-8-digit personal code. When you buy the phone, the phone lock is by default turned off. however if you have changed he lock code then read the note given below
Note: For security reasons, your operator, retailer or Sony Ericsson Contact Center cannot retrieve the lock code through the phone or the network. If you forget the code, locked phones must be sent to a service center.
Thanks for using fixya
7helpful
3answers
SE W910i default security code
Note: For security reasons, your operator, retailer or Sony Ericsson Contact Center cannot retrieve the lock code through the phone or the network. If you forget the code, locked phones must be sent to a service centre.
2answers
Need to unlock a Nokia 6103b
Unlock your phone
  • Press Menu, enter the lock code, then press OK.
Answering a call when the phone is locked
  • Press Answer.
To change the lock code of your phone
Your phone's lock code is used to lock and unlock your phone.
The default lock code is 1234.
  1. Use Menu 4-3-2-3 (Settings - Security settings - Access Codes - Change lock code) to change the lock code.
  2. When the phone requires the lock code, it displays "Enter lock code:".
  3. Enter the code, then press OK.
If you enter a wrong lock code five times in succession, your phone prompts you for the security code.
Saving the unlocked phone number
Use Menu 4-3-2-2 (Settings - Security - Settings - Unlocked phone number) to save a number that may be called even when your phone is locked. You will be required to enter the lock code.
  1. Calling the unlocked phone number.
  2. Press the Up or Down arrow keys or or manually enter the number exactly as it is saved, then press Call.
Note: The More key will pause the automatic scrolling of the help text. Pressing the More key or the Up or Down arrow keys will toggle through the pages. The More key is only displayed when the help text is displayed.
1helpful
Nokia 6500 slide help i need restriction code
PLEASE READ FULL INSTRUCTIONS BEFORE DOING ANYTHING
TRY WITH NO SIM CARD IN THE PHONE
Doing this is at your own risk!
Every code unlocks a certain lock. Code number 7 usually unlocks them all but some phones are 'buggy' and will not accept code 7 at first then use code 1.
Usually you only have to use code 1 or code 7.
#pw+xxxxxxxxxxxxxxx+1#
1. Press ( # ) on your phone
2. To get ( p ) press ( * ) 3 times within 1sec
3. To get ( w ) press ( * ) 4 times within 1sec
4. To get ( + ) press ( * ) 2 times within1sec
5. Enter the 15 digit code
6. To get ( + ) press ( * ) 2 times within 1sec
7. Enter code number
8. Press ( # ) on your phone
Now your phone is unlocked!
If your phone isn?t unlocked after code 1 or code 7 then you have either entered the wrong IMEI or Network. Sometimes there could also be a problem with newer software versions. Then you can try another 'Boxserial' Remember! You have only five tries to enter the right code. After that you will need a cable to unlock your phone. So please, be aware
Phone type: DCT4
IMEI: 352027025104628
Model: 6500
#pw+319926630701132+1#
#pw+702310427045122+2#
#pw+754840072200550+3#
#pw+093433717136641+4#
#pw+199064315752575+5#
#pw+286305406405613+6#
#pw+307016424512121+7#
There is 4 locks on a Nokia DCT4 phone.
Lock 1: MCC+MNC (Network och landsspecific)
Lock 2: GID1 lås (SIM-card typ)
Lock 3: GID2 lås (SIM-card typ)
Lock 4: MSIN lås (SIM-card specific lock)
The generated codes open up one or several locks.
Code 1 open lock 1
Code 2 open lock 2
Code 3 open lock 3
Code 4 open lock 4
Code 5 open lock 1 and lock 2
Code 6 open lock 1 lock 2 and lock 3
Code 7 open lock 1 lock 2, lock 3 and lock 4
Let me know if you have any problem follow these instructions and you should be ok.
I think it needs to be done with no sim card in the phone remember you only get 5 goes after this if its still not unlocked then the only other option is with a lead and unlocking software.
This should solve your problem let me know how you get on ok
This is done at your own risk!
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
