1. Open door
2. Press clock/Kitchen Timer button the display will show "0:00" with the hour"0" flashing.
3. Enter the correct hour by turning the potary dial. Enter 1-12
4. Press clock/Kitchen Timer button the display will show "0:00" with the minutes "00" flashing.
5. Enter the correct minutes by turning the potary dial. Enter 00-59
6. Press clock/Kitchen Timer. The colon will remain flashing.
7. Close the door.
This comes from the user manual:
To turn dial lock off
1 {MENU} i {#}{2}{5}{1}
2 Enter the same password that was
entered when dial lock was turned
on.
3 {Save} i {Yes} i {OFF}
Note: If you forget the password:
Turn the dial lock off using the following method.
2 Press {*}{7}{0}{0}{0}.
This worked on my KX-TG3611BX and might work on yours: Turn the dial lock off using the following method: 1 {MENU} --> {#} -> {2} -> {5} -> {1} 2 Press {*} -> {7} -> {0} -> {0} -> {0} 3 {Save} -> {Yes} -> {OFF}
You can use the Memo and Jog dial, but try this. From the intercom of the control phone dial 7*1 xxx hh mm 0/1 0/1
where xxx is the extension hh is 12 hour time mm is minute and 0/1 is AM/PM and 0/1 is once/daily
To cancel 7*0 xxx To display 7*2 xxx
Or, wade through the Jog Dial for the R-Timed Reminder.
did you do this...
STEP 1
Turn the number dials to the previously set combination, or to "0-0-0", the factory default combination for Samsonite luggage.
STEP 2
Locate the reset button, usually placed to the side of the combination dials.
STEP 3
Press the reset button and hold it while rotating the number dials to the desired combination. Set this to a sequence easy for you to remember but hard for others to figure out.
STEP 4
Release the reset button after you set the numbers to the new combination.
STEP 5
Test the combination by turning the dials to the new code to open the lock.
if you did this then I'd contact Samsonite Customer Service at 800-765-2247.
Happy New Year
1 Press Menu/Set. 2 Press 0. 3 Press 2. 4 Enter the last two digits of the year on the dial pad, and then press Menu/Set. (e.g. Enter 0, 7 for 2007.) 5 Enter the two digits for the month on the dial pad, and then press Menu/Set. (e.g. Enter 0, 3 for March) 6 Enter the two digits for the day on the dial pad, and then press Menu/Set. (e.g. Enter 0, 1.) 7 Enter the time in 24-hour format on the dial pad, and then press Menu/Set. (e.g. Enter 1, 5, 2, 5 for 3:25 P.M.) 8 Press Stop/Exit.
