Question about Intex 1500 Gph Swimming Pool Filter Pump Above Ground
18ft round pool hayward pump and filter system
SOURCE: Problems with Intex Krystal Clear Model 635 Pool Filter Pump 1500
No, the pump should not be noisy. It sounds like you have picked up a foreign object in the pump housing. you may have to pull the face off to determine. OR the pump/motor is indeed defective and should be returned.
Posted on Apr 28, 2009
SOURCE: I have the 15' X 42'intex metal frame. Pool and
Watch the video at itex.com
Posted on Jul 12, 2009
SOURCE: Hayward pump hose and intex pool
Im thinking that hot glue would not harden completly in a direct sun situation not to mention the potential mess
What I did was go to my local hardware store and bought rubber o rings ( sorry dont remember what size) put them on the fitting slipped the hose over it and clamped on top of that area. Has been fine all summer
hope you figure it out
Posted on Aug 05, 2009
SOURCE: Pump and skimmer instructions on how to
Direction of flow is FROM the skimmer to the pump and back to the jet. Its easy enough to determine which hose is the "jet" hose and which is the suction hose. Put both into the water, or in a bucket and turn on the pump, find the one that is shooting out water, that's the jet hose. On these systems, filter replacement and cleaning is annoyingly frequent if you want it to work even remotely efficient.
Posted on Apr 14, 2010
SOURCE: I bought an older pool pump, 108R. The hose goes
i bought the universal twin pack replacement
A/C Filter Cartridges Fits all pump models using 8 in by 4.25 filters replaces A or C filter cartridges
and it works in mine on the bottom there is a white
round thing that holds it there and the top is a black ring with a big round thing then the top with the hose on it screws on
any way bought at walmart
Posted on Jul 15, 2010
Apr 28, 2014 | Hayward Pool & Spa
Thank you for posting your question here on Fixya.com.
32' round by how deep? Flow rate is how you size a filter so with total gallons you can calculate how many per minute will add up to the whole pool being turned over is 6-8 hours. The pump and filter are then sized for that required flow...Assuming the pool is an above ground ~4' average depth then total gallons would be about 24,000 gallons. For an 8 hour turnover you would need about 50 gallons per minute. The 210T, T for top mount, is designed to handle up to 44 gallons per minute and turn over a 21,000 gallon pool in 8 hours or a 26,000 gallon pool in 10.
What that basically means is that using a 210 on a pool 32 x 4 would be pushing it. It will work but you will end up backwashing more frequently which raises the overall cost of running the pool. If it is not to late a 24" filter would be better; especially if you have periods of time in your pool season where heavy amounts of debris such as pollen get into the water. A 21" filter won't handle any over a normal filtration load.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
Apr 28, 2011 | Hayward Pro Series 21" Above Ground Pool...
Aug 30, 2010 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
Aug 14, 2010 | Intex Krystal Clear Model 635 Pool Filter...
Jul 02, 2010 | Hayward Pro Series 18" Above Ground Pool...
Jun 05, 2010 | Hayward Pool Products 25 Sq Ft Micro Clear...
May 31, 2010 | Hayward SAND FILTER, PRO SERIES
Jun 28, 2009 | Hayward SAND FILTER, PRO SERIES
Jun 04, 2009 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
80 people viewed this question
