SOURCE: nokia n76
NOKIA SERIES 60
If you ever tried debranding the phone youself and made a pigs ear of it, and your phone says " phone start up failed, contact the retailer" below is a way of reformatting the phone back to the original factory settings.
1 power the phone off,
2 press and keep down the keeys green/talk + '3' + '*', - power on the phone at the same time
3 release the keys when the formatting starts.
SOURCE: mobile startup failed . contact the retailer
hi,
Your phone's memory card must be infected with virus or has some fault. Please remove the memory card and try to start the phone again. If it goes through, please back up the data in your memory card and format it. In most cases, this procedure solves the "Phone start up failed. Contact the retailer" error.
I'd advice you to format your phones internal memory as well, it will flush out any errors present. save your "phonebook" data somewhere and Make sure your phone's battery is fully charged if not plug the charger in and proceed. NB: interrupting this process might render your phone useless. So, be careful.
To format press *#7370# it will prompt you for security code, enter it and the phone will reboot. Your phone will be reset to "factory settings."
SOURCE: phone startup failed Contact the retailer.Nokia
Problem: Nokia 7610 startup failed contact the retailer
Solve: You Need to format your mobile and this is the way
First of all Turn Off Your Mobile Phone
[ format = power + press & hold call + * + 3 ]
SOURCE: nokia n72 phone startup failed
turn off the phone, press 3 + green key + *, then turn on.. just hold the 3 buttons.The phone will be formatted.
SOURCE: phone startup failed contact retailer
Just format the phone by pressing * + 3 + green button and switch on the phone. But don't release the three button until it start in normal mode.
