Question about Refrigerators
Have extra older Frig in th garage Mod 596.72232200
Have this older frig with freezer on the bottom. Freezer is fine and stays cold but twice now the frig compartment has quit cooling. The other day when I had given up on frig compartment ever cooling awhile back I came home and found water in the garage floor and all and opened the frig and it was cold again. That lasted about 4 days and now it is warm again.
Posted by Randy Branham on
Just Appliance Repairs
    New Friend:
  • 76 Answers
Sounds like a intermittent problem with the defrost timer. Sometimes they get stuck. Check continuity of the defrost heater and defrost thermostat. If both are good then replace the defrost timer, that should solve the problem.
Posted on May 30, 2014
5 Related Answers
dididsaythat
Mike Johnson
  • 291 Answers
SOURCE: frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Posted on Aug 28, 2007
Krazytech
Franklin Ouchida
  • 725 Answers
SOURCE: frig not cooling and now freezer is frosting
Val sounds like a defrost problem..go ahead and defrost your freezer again... check your evaporator drain your fan motors let let me know and I can help you Krazytech
Posted on Mar 30, 2008
Carmen Mikulic
  • 415 Answers
SOURCE: HSS25IFMDWW- freezer frosting up but working
sounds like the defrost thermostat or you may have a crack in the water line causing the freezing.
Posted on Sep 13, 2008
jumptrout51
steve
  • 3361 Answers
SOURCE: water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Posted on Mar 11, 2009
Anonymous
  • 3 Answers
SOURCE: PLHS69EGSS1 Freezer not cooling properly but Frig is OK
try to check the defrost thermistor and also make sure that the unit is working with the right FULL LOAD AMPERAGE by looking this we will know if it has exact refrigerant in the system.
Posted on May 10, 2009
Compressor hot, freezer not cold. what can I do.
do you have frig side by side model or another top freezer bottom frig pls clear it.if you have side by side then replace freezer fan motor..it will work fine.
Oct 09, 2015 | Refrigerators
I have a new frig that I keep in my garage to keep extra food and drinks in. Since the weather turned cold, the freezer is not working properly. The frig still seems to working great. Can you help with...
If the ambient temp is below 52 degrees the unit will not work properly throught the cycles you will need to get what is call a garage kit to install in the unit.
Dec 25, 2010 | Frigidaire FRT21H8 Top Freezer...
Bottom frig is not cold enough. just connected after 1 yr
Ok do this. Boil some water in a pot then use that to defrost the freezer. This is caused by ice build up in the vent that is keeping the cold air from coming into the refrigerator. Make sure it is defrost completel though cause the ice that is built up is mostly inside and can't be seen. That will solve ur problem I guarantee. Then set the temperature to normal. Like half way. This keeps the frost from building up. Believe it or not as refrigerators get a bit older they actually get even colder and therefore frost build up is more likely. Since no refrigeration can be made completely leak proof, small amount of the freon has leaked out older fridge, and this actually cause it to get colder. You don't need a service technician just defrost then set to a lower setting thats it.
Feb 11, 2010 | LG LRTC19314ST Top Freezer Refrigerator
Whirlpool frig. Freezer warm, frig seems ok.
Since the temperature is already 40°, the cold control is satisfied and will not run. Thus the freezer will warm up to 40°.
Jan 06, 2010 | Refrigerators
I have an sqd26vw frig. Both the freezer and frig upper sections get warm, while the bottoms still stay cold. I unplug for two days, then it seems fine again for about one month. Any suggestions?
hi , your defrost is bad and your freezer build ice till no cold air can floe from the freezer to the frig section...
your freezer cabinet need to get all out and open the back wall.
  1. you have 2 element that can be check one is the heating element , two is the thermostat.
  2. you need a volt meter to check them.
  3. if the frost is all over the coils then one of the element i told you before, is bad
  4. if the frost is in one area not all over then you got gas leak.
  5. good luck 911service today . com
  6. I hope you find this Very Helpful and best regards!
Jan 05, 2010 | Refrigerators
Freezer is working fine, but frig is warm,
Look for the return vent near the bottom probably behind the crisper. You'll have to remove it to see the vent. There may be an adjustable flap in to to adjust the meat keeper area. Make sure it's open.
Aug 22, 2009 | Kenmore 53642 / 53644 Side by Side...
Frig not cold
check to see if the back wall of the freezer has ice build up if so that will be an automatic defrost problem
May 02, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Water collects on shelves and below the crisper bins at bottom
Mar 11, 2009 | Refrigerators
Whirpool frig. freezer works frig doesn't
access to the evaporator fan is in the freezer behind the rear wall.
Feb 18, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Marvin
Marvin
john h
