I have a uniden bearcat scanner and cant pick up my local police dept. I put the frequency in and still dont hear anything. I have a bc145xl 16 channel scanning radio and want to know if its compatible...
If you programmed the correct frequency, you should be getting reception. Check www.RadioReference.com to verify the frequency. Otherwise, you may be too far from the transmitter to receive signals. Try your scanner in other locations, check your antenna, and try receiving the PD on another scanner.
The MARCS - Ohio Multi-Agency Radio Communications system - is a Motorola Type II SmartZone Omnilink Trunking system that utilizes APCO-25 digital transmissions. Your BC145XL is not compatible with trunking or digital systems. In order to follow the MARCS you will need one of the following scanners:
GRE PSR-500, PSR-600
Radio Shack PRO-106, PRO-197, PRO-96, PRO-2096
Uniden BC250D, BC785D, BC296D, BC796D, BCD396T, BCD396T, BCD996T, BCD996XT, or the brand new HomePatrol-1
Bill B.
Listening in since the 60's
