Goes through post then stops at blinking cursor
Is the drive making any sounds, beeps, or sounds like clicking after revving up? Might need new hard drive, I had same laptop do the same thing, when it got to post, cursor of death= hard drive died. Also note that you need to replace it with a low GB drive, ATA or SATA not IDE. Try and get 80 - 120 gig if it does need replacing. For some reason I remember it wont run anything over 240G.
Good luck.
tried this and it worked on my Toshiba m35x-s111:
Ready?
1. Remove all connections to the laptop. (USB, power, etc.)
2. Remove the battery.
3. Press and hold the power on button for 1 full minute.
-> Explainer. Yes, many machines only require 10 or 15 seconds but this reset instruction is generic and I've found people hold the button for 9 or 14 seconds so let's write the full minute.
4. Let go of the power on button.
5. Slip in the battery pack.
6. Plug in the power to the laptop and to the wall.
7. Do not plug in any other devices.
Try the power on button!
SOURCE: PROBLEM WITH MY SATELLITE M35X-S111
Check to see if your Display is bad or Video is bad..
To Do This....
Plug an External Monitor into the laptop serial port..Boot the laptop and use the function key plus F5 to boot to external screen... If you see your PC running on the external screen it is a Video card/chip problem.....
Do your lights run ..the Power Light/Battery light/ hard drive light??? Do you hear the hard drive spinning??
SOURCE: need ''audio driver'' Toshiba Sat M35X-S111
Hi, I assure you that if you use the page of Toshiba conseguiras the driver that you need for your laptop. try it. And if you use Recovery's disc that comes with your equipment be able to very easy.
SOURCE: SATELLITE M35X-S111 USB PORTS NOT RECOGNIZING CAMS, PRINTERS & R
PLEASE CLEAR UR QUSTION IF U KNOW HINDI DN TELL ME N HINDI
SOURCE: My M35X-S111 keeps shutting down
More than likely it is overheating you can buy a can of compressed air and blow it out if you dont have a compressor that should be done at least every 6 months
SOURCE: toshiba satellite m35x-s111 will not power up
there was a massive recall on these laptops years ago entailing that the mother board be replaced. unfortunately that is gone and passed. this is a problem with every m35x and most honest repair facilities shy away from those repairs due to the likelihood of the machine failing again.
