Question about Ariston Technologies AW125NA 13 lbs. Load Capacity Washer
The ariston washing 125 show h2o on the scrim
Ariston arxf 125 flushing h20 on the scrim
Dado
    Master:
  • Ariston Tech... Master
  • 509 Answers
The washing machine fails to load water (The wording H20 is displayed).
  • The water inlet hose is not connected to the tap.
  • The hose is bent.
  • The water tap is not turned on.
  • There is a water shortage.
  • The water pressure is insufficient.
  • The START/RESET button has not been pressed.
Dado
Posted on Oct 06, 2015
  • Mario Muns
    Mario Muns Sep 17, 2018
    Perfect, the correct answer. Thanks
5 Related Answers
Anonymous
  • 123 Answers
SOURCE: Dishwasher, Ariston LI62, kept flashing on R
hi there.....this usually happens when the base of the machine is full of water.....switch the machine off ....remove the two plactic inspection panels at the bottom of the machine and dry out the base....check that all fittings and fixtures in the main cabinet are secure and not leaking..particularly the transfer tube from the wash pump to the upper spray arm..(machine needs to be pulled out of its position to check this as it is at the rear)
regards Sir Galahad
Posted on Aug 18, 2009
Anonymous
SOURCE: ariston a1600wd not working
There is a filter of sorts in the pump inlet pipe, its a big item catcher coins etc, but thats got nothing to do with the module error wich is a pricey item at £120! I've had one go already and in the last year, a inlet valve plus a control pcb panel in fact its almost a NEW machine! i'll never buy another hotpoint or ariston again. The machine is two yrs old!
Posted on Apr 29, 2009
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
Posted on Jul 24, 2009
Anonymous
SOURCE: Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Posted on Jan 23, 2010
Anonymous
SOURCE: do you have a manual foe AV61 ariston washing
Manual for this machine can be found at:
http://www.instructionsmanuals.com/u2/pdf/lavadora/Ariston-AV61-en.pdf
Posted on Feb 16, 2010
I am looking for user manual for washer maskin ariston AVXL 125
This should do it.
http://www.manualslib.com/products/Ariston-Avxl-105-3182207.html Ariston AVXL 105 Manuals
Sep 02, 2015 | Ariston Technologies Washing Machines
Why when I put the washing in 30 min wash the manching is flushing h2o
H2O means the applionce isnt getting enugh water but it sounds to me like youre waste hose is to far down your stand pipe it should be in no more than 4 inches and also make sure you are connected to the cold feed not the hot.
May 30, 2014 | Ariston Technologies AW125NA 13 lbs. Load...
My ariston 125washing machine is flushing H2O on the scrim
displayed).
• The hose is bent.
Dado
May 29, 2014 | Ariston Technologies AW125NA 13 lbs. Load...
Ariston washing 125 is flushing h2o on the screen
displayed).
• The hose is bent.
Dado
What is the meaning of H20 which display on ARISTON wasing machine
May 24, 2014 | Washing Machines
Ariston h20 errors
displayed).
• The hose is bent.
Dado
Jan 14, 2014 | Ariston Technologies AWD 129 NA Washer/...
Ariston ARF 105 H2O error!
I had this issue also and it was because I started the machine and had not turned on the water to it. However, it cleared when I unplugged the power cord, waited about ten seconds, then plugged it back in. I guess they need a "reboot" once in awhile, like a computer - at least mine did. Hope this works for you, too.
Nov 05, 2013 | Ariston Technologies Washing Machines
Ariston Margherita ald 1 40 Error code H2O
H2O is the symbol for WATER and probably indicates a WATER related fault on your machine. A pressure switch is the normal way the machines 'sense' when the level is sufficient. Overfilling suggests a faulty switch, which will need to be replaced by a technician. Also, ensure that the machine drains as it should, if not, the pump filter may be blocked.
Jan 03, 2018 | Ariston Technologies Washing Machines
Error messages on my Ariston AVXD109
displayed).
• The hose is bent.
Dado
Sep 07, 2008 | Ariston Technologies AWD121WH
Washing Machines Logo
206 people viewed this question
Top Ariston Technologies Washing Machines Experts
Marvin
Marvin
Harrie
ray gallant
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
