SOURCE: Our GE Profile Oven is not heating up (stove works)
Please check here for possible troubleshooting steps:
http://www.repairclinic.com/0088_13_1.asp#Level1_2
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
SOURCE: Oven not working
This is either a faulty display panel, or a short inside the oven that is causing the panel malfunctioning.
The wirings, elements (both), thermostat contacts inside the oven must be checked for an eventual short. If there is none, replace the control assembly.
You find parts and diagrams here, just enter the correct model number.
SOURCE: GE Profile stove not working
If neither bake or broil ignitors work you must first verify voltage to the parts.
Most likely a defective electronic control.
SOURCE: GE Profile Oven does not work although stove does
Check and or replace the glow bar ignitor.
SOURCE: GE Profile Electric Stove - Buttons for oven don't work
We had a bunch of storms roll through the area and we figured a surge must have fried our control panel. We decided to buy a new oven rather than spend $200 fixing this one. Luckily, our local Sears rep wasn't in it just for the commission and suggested we flip the circuit breaker off for 10 minutes to allow the range to reset itself. Works good as new! So, try this first before you make a decision. Good luck!
