Question about Acer Extensa 5420-5687 Notebook
My acer laptop turns on then turns off
It turns on then off. It did stay on for a few minutes earlier and i tryed to factory reset it but i forgot the pass word. HELP!!!!!!!
5 Related Answers
pgh_pa_guy
  • 2992 Answers
SOURCE: Backlight wont stay on
The inverter board which provides the backlight power isn't working properly. This is a pretty common problem with LCD screens. The inverter is in the display, mounted under the display panel. It's a fairly simple job to replace the inverter. You have to remove the screws holding the front of the display to the back and separate the pieces. The inverter is held in place by a couple of screws and has a couple of cables connecting it to the main board and display panel. Unplug those, remove the inverter, mount the replacement and plug the cables back in. Then reassemble the display. A search on Google for "acer 5315 inverter" turned up several sources for the replacement part. Here is one. I don't know anything about this seller; I just picked it as an example.
Posted on May 19, 2009
Anonymous
  • 40 Answers
SOURCE: can not remember password so i can reset laptop to factory settin
the only way u can reset ur password is to remove ur mother board and cross wire the bios chip with power on i can send the directions if ud like please email me at
[email protected]
my name is mark
Posted on Jul 19, 2009
etaf
wayne walker
  • 779 Answers
SOURCE: factory reset my laptop
NOTE - you will lose all your data and any installed programs if you do a full factory reset. the process will restore your PC back to how your purchased it
This link will explain how to factory reset the PC using Supplied recovery CDs if you have them http://support.acer.com/acerpanam/desktop/0000/Acer/Veriton5100/Veriton5100faq19.shtml
This link will explain how to factory reset the PC using the ACER eRecovery if installed on your PC
http://support.acer.com/acerpanam/desktop/0000/Acer/AspireE360/AspireE360faq67.shtml
If you do have the eRecovery hidden partition installed:- How to recovery your system from bootup
  1. Locate the Alt key, to the left of the space bar, and F10, on the top row of keys.
  2. Power the system on.
  3. When the system is powered on, tap the Alt and F10 keys together at the same time when the Acer splash screen appears.
    It should state "Please wait a moment..." with the Acer logo in the upper left hand corner.
  4. At the eRecovery Management menu it will ask you how to restore.
  5. Click on the restore option you would like to use.
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Posted on Apr 03, 2010
Testimonial: "thanks very helpful"
Matt Stimmel
  • 3 Answers
SOURCE: Acer erecovery management isn't working
do you have anti-virus software? What are you running on it Windows ? what 7, vista, xp?
Posted on Sep 17, 2012
gauravkumar6
Gaurav Kumar
  • 560 Answers
SOURCE: im trying to reset my acer to factory settings and
Unlike other laptops, Acer laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer laptop to factory setting.
Step 1: Before starting your Acer laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer laptop to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer laptop is reset to factory settings.
Tips: You can also create a backup copy of your laptop data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
If you have any other issue with your Acer laptop/desktop/Notebook, feel free to get expert technical assistance at
http://www.vtechsquad.com/acer-support/
Posted on Sep 20, 2012
I have an acer aspire ax1430-uw30p boots up, but screen stays black, cant even see setup menu, can someone help please...
Try resetting the Bios. Remove the ram chips and if you can get access to it, the button battery on the motherboard. Wait a few minutes then put it all back in and boot up. If that won't work, try the steps at the link below, or try them first if you prefer.
http://www.pctechbytes.com/acer/acer-aspire-system-recovery-partition/
Feb 18, 2015 | Acer Computers & Internet
I want to restore my Acer AOA 150 ( mini netbook) to factory default setting. The problem is that Acer Recovery Management is not working. when i click on it No action it takes plz tell me the...
Unlike other laptops, Acer laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer mini notebook to factory setting.
Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer mini notebook to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer mini notebook is reset to factory settings.
Tips: You can also create a backup copy of your notebook data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
If you face any issue with your Acer Notebook, feel free to get expert technical assistance at
Dec 25, 2010 | Acer Aspire One AOA150-1504 Netbook
My son forgot his password in his acer aspire netbook how do we reset his password? we tried the reset bar and that didn't work. help
The experience forgot admin windows password happened to me few days ago. And I searched in the Internet to find the solution. Then I found a windows password reset tool called Windows Password Reset have a good evaluation.
I tried it as the steps:
Step1:Download and install Windows Password Reset
Step2:Burn Windows Password Reset ISO file to CD/DVD,or USB.
Step3:Put in my newly created CD and remove my Windows Password.
It really great help to me reset windows admin password.
Hope it help your son too.
Nov 03, 2010 | Acer Aspire 5050-3242 Notebook
Upon turning my acer 5517 laptop on it goes to Enter CURRENT Password i cant get past that
Is it in Windows XP OS? try pressing F8 upon restart of your laptop then select safe mode. click on the administrator account. You may remove password if you forgot it.
Hope this helps.
May 22, 2010 | Acer Aspire 5100 Notebook
Laptop battery went dean charged up pc stioll not turning on battery light just shuts off when press power button and stays off until power cord unpluged and then pluged back in
With power off and unplug from the power supply, remove battery pack from your laptop for a few minutes to force it to 'hard' reset.
Hope it works for you!
Try again and let me know.
Jan 01, 2010 | Acer Aspire 5500 5570-2609 Laptop
I need to reset my aspire 4315 series back to factory settings as it's not running properly, I've lost my hand book and can't remember what to do, could you possibly tell me what buttons to press when to...
First plug in the Notebook to a power socket with your adapter. Power on the Notebook and you will see the Acer splash screen. Immediately prell ALT and keep tapping F10 at the same time. It will take you to a screen where you will see "windows is loading files" or "starting acer recovery" it will ask you, how do you want to restore?" choose the option "restore to factory default" and click continue. It will go through the restore process and within 15 - 20 minutes it should finish the process. Your Notebook will be back to factory default settings and once again you can see the OOBE.
Hope you find this solution helpful.
We appreciate your comments and feedbacks, Please do not forget to leave your comments and ratings.
Thank you for choosing Fixya.
Nov 15, 2009 | Acer Aspire 4315 Notebook
Laptop has virus, need to restore to factory settings
you can try using windows system restore : Which restores your machine to an earlier date.
Start : Programs : Accesories : System tools : System restore.
Thanks,
Fame !
May 31, 2009 | Acer Extensa 4620-4648 Notebook
I HAVE A PC LIKE GIFT BUT ASK ME FOR A PASSWORD AND THE PERSON THAT GIME ME THE PC SHE FORGOT THE PASS WAHT CAN I DO
Remove battery for a few minutes and re insert.This sets it back to factory settings. Just reset time and date in the bios and you should be away.
Aug 09, 2008 | Acer Aspire 3000 Notebook
Acer Extensa 5420-5687 Notebook Logo
80 people viewed this question
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
Michael Thomas
Michael Thomas
