I have directv cable and the tv is controlled by the remote from directv and won't login tv code to the remote to shut off or put on and have to shut tv off manually. The tv main menu keeps going through each faze when I put it on and even without the directv itself is on and none of the other switches in the front work including volume only off and on switch work. Would it be worth fixing or junk it and buy a new tv?
SOURCE: remote control not working
is the remote original and ment for the television? if not I would suggest a universal remote from any local retail shop to replace the non working remote.
SOURCE: How to get TV/video mode without remote
some tv do that changing the channels.
in the control panels in the tv where r the buttons for change channel there must be video button, push it and there you go.
Good Luck
SOURCE: i was watching tv when suddenly the volume control
The front panel Tactile Switches probably need to be replaced. The part # of the switches is 23344507. You can order them through Encompass Elect. 800-638-3328.
Hope this helps,
Skyassoc
SOURCE: Sometimes the on/off switch doesn't work and we
Could have a bad power switch or a bad ground on the switch itself. Will the original remote work to on and off the tv every time? If not you may a bad filter cap or two near the horizontal deflection.
SOURCE: I lost my remote and need to switch the tv so I
I can help you with your Toshiba TV & DirecTV remote control.
To get your TV setup so that you can view your DirecTV on it, I recommend you program your DirecTV remote to control your TV and then use the DirecTV remote to change the input of your TV to view the DirecTV programming.
You can choose between searching for the control code and
entering a code from the Toshiba TV list.
This
is a list of all the Toshiba TV control codes for DIrecTV remote
controls:
11524, 10154, 10156, 11256,
10060, 12006, 11945, 11936,
11935, 11918, 11704, 11656,
11635, 11369, 11356, 11343,
11325, 11306, 11156, 10845,
10832, 10822, 10650, 10149,
10148, 10036, 11971
I hope that helps.
_________________________________________
DirecTV Remote Control Code List
Download
DirecTV Remote Control Manual Download
DirecTV Remote Control Code Entry
Search
Onscreen Setup
