Motorola MH230R  Two Way Radio Logo
A
Anonymous Posted on May 29, 2014
HOW DO I RESET BACK TO FACTORY SETTINGS? - Motorola MH230R Two Way Radio
ka4iup
Level 3:
  • Motorola Master 4,062 Answers
  • Posted on Aug 02, 2014
ka4iup
Motorola Master
Level 3:
Answers
4062
Questions
0
Helped
1095356
Points
51404
There are no factory default settings. Just program each channel as you desire.
How to reset to factory settings on a piranha max210 depth finder
To reset a PiranhaMAX 210 depth finder to factory settings, follow these steps:
  1. Turn off the unit by pressing and holding the power button.
  2. While holding down the "Zoom-in" and "Zoom-out" buttons on the keypad, press the power button to turn the unit back on.
  3. Release all three buttons when the unit beeps and the "PiranhaMAX" logo appears on the screen.
  4. The unit will now ask if you want to restore factory defaults. Press the "Menu" button to confirm.
  5. The unit will ask if you want to restore all settings to the factory defaults. Press the "Menu" button again to confirm.
  6. The unit will then reset all settings to the factory defaults and reboot.
Note: Resetting to factory settings will erase all user settings, including saved waypoints and custom settings, so be sure to back up any important data before resetting.
Jun 02, 2018 • Boating
I lost my romote to my roku and it got reset. how do i set it up again without the remote
Hello
Reset Roku without Remote:
Soft Reset
From Menus (Newer Models - 4, Premier, & Ultra)
1. From the Home screen, select "Settings" > "System" > "Power" > "System restart".
Using Button (Older Models)
1. Find the "Reset" button on the back or bottom of the device. Some models will require a paper-clip to press the button.
2. Press the button, then release after about one second. The device should reset successfully.
Power Pull If none of the above soft reset options work for you, you may need to disconnect the power cord for about 20 seconds, then plugging it back in.
Hard Reset
A hard reset will clear all settings from the device and reset it to factory defaults.
Via Menu (Newer Models - 4, Premier, & Ultra) If a soft reset doesn't fix your problem, a hard reset may be your only option. This will clear all data off the Roku and reset it to factory default settings.
From the Home screen, select the following depending on your device:
1. "Settings" > "System" > "Advanced system settings" > "Factory reset".
2. "Settings" > "Factory reset" > "Factory reset" > "Yes".
1. Remove all cables except the Power cord.
2. Press and hold the "Reset" button on the back or bottom of the device for about 20 seconds. Some models will require a paper clip to press the button.
3. Continue to hold the "Reset" button, then remove the Power cord from the back of the unit.
4. Release the "Reset" button, then plug all of the cords back into the device.
The Roku should factory reset, then walk you through the setup process again.
For any help Visit us: www Support Roku Com
How do I reset my proscan tv set modle number PLDED399A back to factory setting with my remote
There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
1helpful
2answers
My nabi dreamtab wont reset why?
There are two types of resets that you can perform on nabi - forced reboot and factory reset. In the unlikely event that your nabi becomes unresponsive, you can easily perform a forced reboot. A factory reset is recommended when slow performance persists or if you want to wipe out all of your personal data and settings from nabi. Forced Reboot: To perform a forced reboot, hold the Power Button down until nabi turns off. When nabi is off, press the Power Button to turn on nabi again. Factory Reset: Caution! A factory reset is a very serious process because it will SYSTEMATICALLY WIPE ALL USER DATA from nabi. A factory reset will return nabi to its original factory settings.To perform a factory reset from Mommy/Daddy Mode, tap All Apps > Settings > Backup & reset > Factory data reset > Reset tablet > Erase everything. Please note: We highly recommend backing up your nabi prior to performing a factory reset. You can back up your music, videos, photos and apps with nabi™ Sync.
Reset to factory settings on Samsung galaxy 10.1
Go to applications, settings, back up and reset. If you want to save your data check the "back up my data" box, then tap the "factory data reset" and tap the "reset tablet" tab. The tablet will then be reset to the original factory settings.
Netflix com
Performing a factory reset
Performing a factory reset erases all of your settings and account information and restores your
1 Press home to go to the Home screen. 2 Highlight settings , and then press select to display the Settings screen.
3 Highlight factory reset, and then press select .
4 To continue with the reset, select factory reset. To cancel the reset, select back.
  • 5 When prompted, highlight yes to confirm that you want to reset your player, and then press
    select
Password reset on blaupunkt tablet
How do I reset the device to factory settings?
Tap on: Settings---Back up & reset---Factory data reset, to reset the system to
factory settings.
http://www.blaupunkt.com/uploads/tx_ddfproductsbp/HW-Manual-Vollv_Android4.0.3_Endeavour_TV_seven_Engl.pdf
2answers
Zoom R16 factory reset
To perform a factory reset on the Zoom R16 recorder, follow these steps:
  1. Power off the Zoom R16 by pressing and holding the [STOP] button.
  2. While holding down the [STOP] button, press and hold the [REWIND] button and the [PLAY] button.
  3. Continue holding all three buttons for about 5 seconds until the display shows "Factory Reset."
  4. Release all three buttons and the unit will automatically restart and restore all factory settings.
Note: Performing a factory reset will erase all user data and settings, so be sure to back up any important data before proceeding.
Go back factory condition
Hello Cynthia,
There are several ways to achieve this.
Reset phone
The Reset feature allows you to set your phone options back to
  1. From Idle mode, touch Menu-> Settings -> Phone -> Reset phone.
  2. At the "All settings reset to factory defaults. Continue?" prompt, touch Yes to reset, or No to cancel. Once your phone has been reset to its default settings for those selected options, it will restart itself in order to incorporate the new settings.
Restore phone
The Restore feature allows you to delete any user information
that has been added, in addition to setting your phone options
back to the factory defaults.
  1. From Idle mode, touch Menu-> Settings -> Phone ->Restore phone.
  2. At the "All settings reset to factory defaults and all user data will be deleted. Continue?" prompt, touch Yes to reset, or No to cancel.
or
Reset code
Enter *2767*3855# in phone dial.
Warning! All your data including contacts, messages etc. will be lost! Copy all your necessary data/Contacts/Messages etc. to SIM or make backup on your PC before full reset!
Router name was reset without my asking. i need to set it back.
how was the name reset and by who??????
if you mean you have to reset your router to the factory default settings
(note all settings will be lost you will need to reconfigure the router)
you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, depending on your router) to reconfigure your router settings or if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
Top Motorola Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
