Question about Rio Carbon MP3 Player
How can i reformat my rio carbon
My rio carbon shows no tracks although i have loaded tracks onto it via rio music manager
Posted by christoper cooke on
5 Related Answers
Anonymous
  • 277 Answers
SOURCE: Rio Carbon 5gb pearl transfer problem
hi first of all update uour firmware: http://www.replaytv.com/support/rio/product.asp?model=267&SKU=90260554 also go to Software tab and update your Music Manager i belive this will solve all your problems good luck
Posted on May 08, 2006
Priya darshan
  • 3422 Answers
SOURCE: Grace Note not working in Windows Media or Rio Music Manager
The SD memory is probably seen as a separate drive from the perspective of Windows Explorer and Rio Music Manager.
For example, if F is your Forge internal drive, then you probably have a G drive that represents the extension memory.
If so, add the additional drive as a music location in Rio Music Manager and see if that helps.
Posted on Feb 12, 2008
mowcius
  • 155 Answers
SOURCE: rio carbon
Just to say to ThaMp3Doctor:
The Rio Carbon supports direct file drag and drop to the player. Please get your facts right before posting comments that are not correct. There are also many programs that will work for file transfer with the Rio Carbon.
The 3.04 developers cut firmware is available here:
http://biomoose.com/files/rio/carbon%203.04.EXE
Mowcius
Posted on Jun 18, 2008
Anonymous
  • 80 Answers
SOURCE: i cant delete file on the rio carbon
Scan for virus, then eject and reinsert it, refresh page over and over again. and try to delete, if it refuses, then you've got to format it.
Posted on Feb 08, 2010
cirocpatel
CIROC TECH SUPPORT
  • 524 Answers
SOURCE: When I transfer music from Rio Music manager to my
Try to transfer the tracks from the explorer.
1 Connect the Rio Carbon to a computer using the supplied USB cable.
2 Double-click My Computer on the Windows Desktop or in the Start Menu.
3 Locate MP3 or WMA audio files on the computer.
4 Highlight files and/or folders to transfer to the Rio Carbon.
5 Click Edit.
6 Click Copy.
7 Double-click My Computer on the Windows Desktop or in the Start Menu to open another window.
8 In the new window, locate the Rio Carbon (X:) icon that is associated with the Rio Carbon. (X equals the drive
letter assigned to the Rio Carbon.)
9 Double-click Rio Carbon (X:).
10Click Edit.
11Click Paste.
Posted on May 25, 2010
Rio carbon wont load any music?
try reformatting it then putting music back on it see how that helps
Apr 27, 2012 | Rio Carbon MP3 Player
you are suffering from the Digital licensing information encryption from the majors, which ITunes will NOT agree to. That's how the music industry is making it's muscle show, with this sort of tawdry nonsense. I don't believe there's a s/w upgrade on this, unfortunately. There is a slight possibility that your software might have an interpreter, yet your Rio being that old, not for certain.
got backup?
Feb 12, 2008 | Rio Carbon MP3 Player
When I transfer music from Rio Music manager to my Rio Carbon the music manager indicates transfer successful but the MP3 player states no tracks present?
5 Click Edit.
6 Click Copy.
10Click Edit.
11Click Paste.
May 24, 2010 | Rio Carbon MP3 Player
Rio carbon 5 gig mp3
The Rio Carbon will not play songs from iTunes unless they are in mp3 format. If you cannot download the songs in this format then I would recommend a program such as mediacoder to convert the tracks. I don't know why iTunes was recommended for the Rio but I would just use drag and drop into the folder called Music on your Rio.
Hope this helps,
Mowcius
Oct 17, 2008 | Rio Carbon MP3 Player
Carbon Pearl: Invalid Argument
Try accessing the rio's hard drive through my computer to see if it can find the songs: they will be in a folder aptly called music within your rio carbon.
If this doesn't help then if it is picked up via my computer you could try wiping and rebooting your rio, read:
http://www.fixya.com/support/r601327-wipe_reboot_rio_carbon
You may have to change the firmware for the rio carbon pearl but this is easy to find on their website.
Hope this helps,
Mowcius
May 22, 2008 | Rio Carbon MP3 Player
How to take music off Rio Carbon
I have bad news - I was completely unsuccessful in dragging tracks from the rio to my computer. You can load songs, but you can't "unload" them with the Rio Carbon.
Just in case your computer has capabilities that mine does not, try this:
Double-click "My Computer" on your PC desktop
Double click the Rio Carbon icon
Double click the "Music" folder
Try dragging a single music file from the "Music" folder window to your PC desktop - it will either work, or it will say that it cannot copy the file to the specified location.
Apr 13, 2008 | Rio Carbon MP3 Player
I presume you are using windows...
Go into start,
Then My Computer,
Your Rio carbon should show up as a removable device, double click on it,
Then you should have 2 or more folders: Music and recordings,
double click on music and all of your music will be in there,
you can then just copy and paste it to your documents or other folders as a backup.
Hope this helps
Mowcius
Transferring music to new pc
You must use the music transfer software that came with the CD (also avail on Rio website) - which will not load on newer, Vista running computers.
May 03, 2007 | Rio Carbon MP3 Player
May 01, 2006 | Rio Carbon MP3 Player
Rio pearl directory corrupted
first, and this is always good: If available, firmware for the Rio Carbon can be downloaded online. Second, this might be the problem: The Rio Carbon communicates with your computer differently in MTP mode than it does in MSC mode. When in MTP mode, the Rio Carbon cannot display hidden files in folders, cannot allow transfers to the root Rio Carbon directory, and cannot allow the creation of new folders. (Folders can be transferred to the Rio Carbon using drag-and-drop and copy-and-paste methods.) To use traditional folder options, change the Transfer Mode settings to put the Rio Carbon in MSC mode. Last, "..Removing the Rio Carbon from a USB connection before Idle is displayed on the screen may result in a corrupting the player's file system. If for any reason you suspect that your Rio player's file system has been corrupted, reformatting the player will restore the file system to its original state..."
Nov 27, 2005 | Rio Carbon MP3 Player
Rio Carbon MP3 Player Logo
Top Rio Audio Players & Recorders Experts
Artur Heise
Jean Sintulaire
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
