Question about Rio Carbon MP3 Player
How do i format my rio carbon - Rio Carbon MP3 Player
Posted by christoper cooke on
5 Related Answers
Anonymous
SOURCE: rio carbon saying "upgreader"
im not sure it'll help but something told me when mine said the same thing that the device needed a new driver. what ever that is.
Posted on Apr 16, 2007
Jean Sintulaire
  • 759 Answers
SOURCE: rio carbon
It sounds like there is a problem with the device firmware..update the device firmware and that should solve the problem you are having...
Posted on Jan 27, 2008
mowcius
  • 155 Answers
SOURCE: rio carbon
Just to say to ThaMp3Doctor:
The Rio Carbon supports direct file drag and drop to the player. Please get your facts right before posting comments that are not correct. There are also many programs that will work for file transfer with the Rio Carbon.
The 3.04 developers cut firmware is available here:
http://biomoose.com/files/rio/carbon%203.04.EXE
Mowcius
Posted on Jun 18, 2008
mowcius
  • 155 Answers
SOURCE: Fixing Rio Carbon Wheel
If you look in the hints and tips section for the Rio carbon then it is there... That link works so I am not sure which link you are referring to.
Hope this helps,
Mowcius
Posted on Oct 14, 2008
mowcius
  • 155 Answers
SOURCE: rio carbon 5 gig mp3
The Rio Carbon will not play songs from iTunes unless they are in mp3 format. If you cannot download the songs in this format then I would recommend a program such as mediacoder to convert the tracks. I don't know why iTunes was recommended for the Rio but I would just use drag and drop into the folder called Music on your Rio.
Hope this helps,
Mowcius
Posted on Nov 03, 2008
BATTERY FOR A RIO CARBON (5GB ) mp3 pLAYER
1. look on ebay for battery if anybody would sell one.
2. go to walmart look in the flash drive isle for a sandisk ultra 2 cf card 8gb about 40$ .
3. open the rio and take out the old hard drive and then find a pc to format the cf card with a cf card reader make sure to format with windows 7 in my computer and choose quick format select default allocation size and then hit start.
4. when succesfully formatted put cf drive in rio carbon.
5. then put back plate back on carbon.
6. then look here for rio carbon developers firmware
http://en.wikipedia.org/wiki/Rio_Carbon
7. go to bottom of wikipedia page and click 3.04 Download link 1 and download the exe program and then run as administrater load up the firmware and then walla you have a working mp3 player again.
Sep 03, 2012 | Rio Carbon MP3 Player
Tip
Wipe and reboot Rio carbon
Many problems have been found with the Rio carbon and although it is a good media player I think most people will have some problems with it.
Many of these problems can be solved by wiping and rebooting your player:
This may fix the upgrader message but if not the try replacing your hard drive (see: http://www.fixya.com/support/r590688-replace_broken_hard_drive_in_rio_carbon)
Windows only... Sorry but I am not familiar with the way to do it with a mac or linux pc...
Open My Computer with your Rio plugged in.
Right click on your Rio player and click on format.
Leave the default values - if it asks you something then use your initiative.
Then click on format.
Then when it has finished formatting go to your firmware (can be downloaded from: http://www.digitalnetworksna.com/support/rio/product.asp?prodID=215).
Follow the instructions and then it should load the firmware onto your player.
When it has done then your player should (in theory!) work properly.
Hope this helps
Mowcius
on May 16, 2008 | Rio Carbon MP3 Player
I am trying to copy my files from my rio carbon to my computer and the computer is telling my access denied.
if your using linux try formatting your carbon if not use windows and see if that works
Aug 04, 2011 | Rio Carbon MP3 Player
How do you restore your carbon back to factory settings? i want to completely delete everything but i don't have the software...i havent for quite awhile. can you restore it just using the device itself?...
You cannot restore the player without a computer but by formatting your drive and re-loading the Rio Carbon Firmware, you can reset it to factory settings.
The Developers cut firmware (latest (unofficial) firmware) is still available here:
Jan 31, 2011 | Rio Carbon MP3 Player
Rio Carbon stuck on Formatting
Leave it for around 2 hours to format. If it is still formatting, pull the cable out. Some of your data may corrupt, but it will get unstuck. Then plug it in again, go to Start>My Computer, right click your player, and select format.
Aug 27, 2009 | Rio Carbon MP3 Player
I cant delete file on the rio carbon
Go to My Computer. Then open the carbon drive, to view the files. Then delete the ones you do not want.
Jun 05, 2009 | Rio Carbon MP3 Player
Filels won't delete
Try re-formatting your Rio
On windows just right click on it and click format.
This will remove any tricky tracks that just don't want to go away...
Mowcius
May 26, 2009 | Rio Carbon MP3 Player
How do i download/transfer my rio carbo mp3 music database to my ipod itunes music manager??
The Rio Carbon is completely incompatible with iTunes (which uses AAC format). It only accepts mp3, wma, and some WAV's. The Rio Carbon is still the best mp3 player I ever owned, but since Rio doesn't make them anymore, it will never be compatible with iTunes. You can use it with Rhapsody's Mp3 Only service, or any music service that gives you the files in mp3 format - but you can't sync the songs through the music service's "synchronize function" - you have to download the files to a location on your computer, and then use the Rio music Manager to transfer the songs to your device.
-Tha Mp3 Doctor
Mar 04, 2009 | Rio Carbon MP3 Player
Rio carbon 5 gig mp3
Hope this helps,
Mowcius
Oct 17, 2008 | Rio Carbon MP3 Player
Rio Carbon MP3 Player Logo
Top Rio Audio Players & Recorders Experts
Artur Heise
Jean Sintulaire
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
