Based on your description, it sounds like your Blaupunkt 32-inch flatscreen TV may have a damaged screen. The ink-like appearance and brief flicker followed by a dark screen are indicative of a physical crack or damage to the screen.
It is possible that the TV was able to function normally after the fall, but over time the damage to the screen worsened and is now causing the issues you are experiencing. Unfortunately, this type of damage is typically not repairable and would require a replacement of the entire screen, which can be costly.
If the TV is still under warranty, you may be able to get it repaired or replaced through the manufacturer. Otherwise, you may need to consider purchasing a new TV if the cost of repairing the screen is prohibitive
1) New batteries are the wrong type.
2) Reset the TV unplug it from the power socket for 5 or 10 minutes and plug it back on,
3) Now try the remotes again.
U.S. Consumer Product Safety CommissionDec 12, 2013 - This recall involves black Coby 32-inch flat screen televisions with model number ... AmTRAN Video Recalls to Repair 42-Inch JVC Flat Panel ...Missing: space
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the ... Just match up the sticker, and also add a space and n8lk, then search on amazon. .... LCD & LED TV Repair - No Image & BlankBlack Screen Flashlight Test ...
iFixitNot Compatible With Coby DVD Player; Disc Types Compatible; Problem Message Displayed On Screen. "WRONG ... Follow the repair guide to replace the fuse inside the device. ... The same goes for the white and yellow plugs and ports.Missing: space
Your tv have problem with the LCD panel drive circuit normally know as timing control board (t con). Normally bellow 32 inch tvs the t con board is integrated to the panel itself. so you have to go for now lcd panel for your tv. www.electro-medical.blogspot.com
IF your LCD is flickering there are 2 possible causes: bad cap(s) in the power supply chain or (almost) died backlight's CCFLs. If you have enough knowledge/hands you can fix both on your own, otherwise to buy a new device is going to be cheaper nowadays.
It probably has a cracked circuit board. If you want to repair it on your own open it up and see if you can find where that cracked section is and see if you can resolder it back properly.
If it is a crack in the lcd screen then the replacement cost is going to be worth more than a new tv, Panels are a very expensive repair and generally not cost effective to do,
