Question about Mitsubishi WD-65731 65" HDTV
Why would my Mitsubishi wd 65638 which shuts off itself after an hour if I unplug for 5 mins it works again for another hr any suggestions
Why would it work sometimes
5 Related Answers
Anonymous
SOURCE: mitsubishi WD-62827---PICTURE TURNS GREEN
I had the same problem. I deducted that if my TV worked fine for an hour or so and then the colors became bad (green, people's faces purple...), it must be a overheating problem. Simple logic, right? So, I picked up a few tools and a small vaccum and went to work.
I went first for the main source of heat: The lamp. Just a few screws, and I removed it. The lamp cage has a fine screen to prevent the dust to cover the lamp. Mine was covered with dust! And the fan behind the lamp was also covered with dust! Bingo!!! That's my problem! I cleaned everything and vaccumed all the air vents on the the back of the TV. I put the lamp back and checked that the fan was working. The TV works like new since!
Before you are out of a TV for days and spend an arm and a leg for a "Technician" to fix it (replacing expensive parts that didn't need to be replaced in the first place), try what I described above first. It's very simple and it takes only 15 minutes.
Since my TV is 2 1/2 years old, I purchased a replacement lamp. I know that one of these days it will burn out. I'll be ready and my TV will be working again in 15 minutes!
Since my problem was solved, I didn't go to the next step. There must be one or two other cooling fans inside the TV, but they must be working...
Good luck,
[email protected]
Posted on Jan 25, 2009
Testimonial: "YES IT IS A HEAT ISSUE(IF YOU HAVING GREEN SCREEN ISSUES LEAVE THE BACK COVER OFF AND PUT A SMALL FAN BLOWING IN THE LIGHTBULB AREA.PROBLEM SOLVED"
Anonymous
  • 53 Answers
SOURCE: RED LAMP LIGHT!!
Check to make sure your lamp is not blown.
Make sure you installed a Mits original, and not a generic.
Make sure the lamp is seated and secured properly, as slight movement can cause a loss of connection.
Slide your set out to the side and peer into it through the slats. Can you see the lamp fire on?
Your symptom does not indicate that it could be a problem other than the lamp and the installation thereof, however---there is an instance where 2 capacitors will blow on the power supply and cause a red lamp light to show. Furthermore, the light engine itself could be causing the problems.
But, since you just installed the lamp, I would look over your installation.
Posted on Aug 01, 2009
Anonymous
SOURCE: Mitsubishi WD 62827 pictures flashes colors
TAKE THE BACK OFF AND LEAVE IT OFF . NOW TRY IT. IT WORKED FOR ME STRANGE BUT IT WORKED
Posted on Nov 18, 2009
Anonymous
SOURCE: I have a Mitsubishi WD 52628. I replaced the tv
try turning it on hold the menu button for eight seconds menu pops up try reseting the settings again as before you had the problem
Posted on Feb 10, 2010
Anonymous
SOURCE: mitsubishi ws-55513 HELP!!!
I have same problem, does anyone have a pic or description to help me identify which "surface mount transisters" he's talking about?
Posted on Feb 22, 2010
65 in wd-65638 looks like dirt inside the scrin
Its not dirt, the light engine is failing and this part is not cheap.
Feb 06, 2016 | Mitsubishi WD-65638 65" DLP HDTV
Mitsubishi WD-65638 turns itself off and I see no status codes afterwards
Press menu and input on front of TV for 5 seconds. Green light will flash two digit code 5 times. '12' is no error(no problem.)
May 22, 2014 | Mitsubishi WD-65638 65" DLP HDTV
I have a mitsubishi wd 65638 . it powers up just fine then about an hour or so in it starts to slutter the colors then settles into a weird silver and grey colors setting like black and white but not
this sounds ilke the board maybe tring to go bad although i know it doe have colored bulbs but it has to be the circuit board this is what control the power distabution
Apr 09, 2014 | Mitsubishi WD-65638 65" DLP HDTV
Tv shuts off
Likely a bad lamp or a color wheel not starting.
Mar 27, 2014 | Mitsubishi WD-65638 65" DLP HDTV
My Mitsubishi WD-65638 turns on then flickers and turns off?
Flickering must be due to the fault to lamp itself. If you wish to get more details, check this link.
Mar 03, 2013 | Mitsubishi WD-65638 65" DLP HDTV
Mitsubishi wd-65734 65 in. Tv shuts off on its own and red lamp light comes on. after a few minutes i can turn it back on and works fine for a few min to an hr before doing it again. anyone no wat the...
Same thing on my tv after replacing lamp. Lamp manufacturer advised me that after changing bulb, tv must be reset or tv will go into safety mode and will not turn on. To do this on my model WD-65734 you must hold reset button in with a pen or paperclip for about 10 secs.The LED will start blinking for a few mins. When itstops you need to unplug tv set for about 1 hour. After this the tv will be reset.
Apr 22, 2012 | Mitsubishi WD-65734 65" HDTV
Mitsubishi wd-65638 65 in hd tv dlp tv usb i dont no how to work it
I think you need to download the manual for you to easy follow how it works...
try this link:
http://safemanuals.com/user-guide-instructions-owner-manual/MITSUBISHI/WD-65638-_E
try to click the right box and click the boy to the left side...rate and comment then download..
Dec 11, 2011 | Mitsubishi WD-65638 65" DLP HDTV
Video on 65 inch Mitsubishi Tv model WD-65638 is not working how may i reset this or even fix the situation.
If you have the original working Mitsubishi remote you can try a soft restart:
Menu, 1,2,3, enter
SD TECH
Aug 31, 2011 | Mitsubishi WD-65638 65" DLP HDTV
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Mitsubishi WD-65731 65" HDTV Logo
98 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
