Question about ULINE U-line 2175Rsod 5.4 Cu. Ft. Outdoor Compact Refrigerator With Left Hin
What can I do to get my laptop computer to turn on?
Posted by Lee brewer on
D & B Enterprises
  • 778 Answers
Hello, What is the make, model, and serial number and manufacturer of the device you want too turn on?
Posted on May 30, 2014
Electrolux freezer will not turn on automatically when termperature warms in compartment, controls don't appear to turn compressor on, any help would be appreciated?
Sounds like your thermostat is bad. You probably have to replace it and the sending unit also. Big job! Look for a manual at : http://www.servicemanuals.net
Apr 28, 2014 | Electrolux Freezers
My slush machine won't turn
You need to be more specific as to what won't turn. Do you mean it won't come on at all or will the it not turn the dasher/scraper?
Mar 23, 2014 | Grindmaster Freezers
Help, i turned by Bosch Logixx GSL 14424 GB freezer off to defrost and it now won't turn on...
Turn it round and check the electrics for the compressor are dry. You probably flooded them when defrosting and may have shorted something. If it still won't start with everything dried out, call a fridge technician
May 02, 2012 | Freezers
Freezer will not come back on
First check the thermostat. It might have gotten turned up when you were cleaning it. If the thermostat is set correctly, the problem might be the defrost timer. It controls cycles the compressor off periodically to turn on the defrost heater. There are wires connecting it to the compressor. It is a little box, a bit smaller than a pack of cigarettes with about 3 to 4 wires connected to it. On one side is a hole with a plastic cam. The cam can be turned with a coin or a flat screwdriver. If it is turned about an quarter turn, it should click. If the compressor turns on after you turned the cam, then the problem is the defrost timer.
Jul 01, 2010 | Frigidaire 14 cu. ft. / 396 liter Upright...
How to make my freezer colder
Hi, some thermostat control knobs and directions to make it colder are different. Here is the best way to find out which way to turn it to make it colder. Make sure you hear it running. Take the control knob and listen carefully while you start to turn it in one direction first. Turn it until you hear the unit shut off. If you turn it all the way to the left and it keeps running, turn it all the way to the right until it stops running. Once you know which way it stops running when you turn it, this will tell you that you need to turn it until it comes back on again and runs. This will be the way it turns to get the temperature to get to a colder setting. When you are doing this, do it very slow and give it about 3 minutes in between each time you start to turn it the other way. On mine it has numbers on it. The higher the number lets say from 1 to 8, the colder it gets, but some are the lower the number the colder it gets. So, you want it to shut off, so wait until you hear it running before you turn the knob. You can open the doors and it will make it come on faster. So when it goes off when you turn the control knob, you will no to turn it the other way for it to come on and it will get colder the more you turn it in that direction. Very easy. PS If it doesn't get colder when you find out which way it goes, you may have a bad thermostat. Please let me know. You can put a thermometer inside to watch the temperature
Good Luck,
Shastalaker7
Jun 30, 2010 | Hoover 9.9 cu. ft. / 280 liter Upright...
Should I turn the setting to High then turn it
It won't get colder any quicker by turning it higher than the temp. you want it to operate.
May 10, 2010 | Danby 5.5 cu. ft. / 156 liter Chest...
Sub Zero 5065 Under Counter Ice Maker
We have a sub zero 5065 in our storage, still unused and in the box. You may want to just buy it at a good deal. Make an offer, it has to go as we are cleaning out the storage are. 360-695-3238 Brian
Mar 18, 2010 | Freezers
Freezer door left open
Your fridge should be fine, if you have surges that frequently getting a whole house surge protection package would make alot of sense. Surges are especially damaging to electronic circuits found in TV's computers, cell phones, answering machines aell frankly in just about everything. Well worth the charge.
May 22, 2009 | Freezers
ULINE U-line 2175Rsod 5.4 Cu. Ft. Outdoor Compact Refrigerator With Left Hin Logo
75 people viewed this question
Top ULINE Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you an ULINE Freezer Expert? Answer questions, earn points and help others
