Astec HPS3KW Which pin is current share?
Posted by Lasershop on
  • 2 more comments
  • Ramano Parks
    Ramano Parks May 29, 2014
    Hi Lasershop , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
  • Lasershop
    Lasershop May 29, 2014
    Power supply is an Astec HPS3KW. 48 volt, 3000 watt. I found documentation easily and can power up the units. They are "Single Wire Parallel" but I cannot find which pin it is supposed to be. The doc has the pinouts but does not state what the pinout acronyms are, "PWOK", "SCL" and so on.
  • Lasershop
    FYI, Single wire parallel = current share multiple units.
  • Lasershop
    Lasershop May 30, 2014
    I dont know what more I can add. Could use this solution ASAP. There will be that one pin (current share) that will hook to the same pin on the other unit so I can get all the amps from both units. Most jobs wont even use more than 40 amps but I have one lasercutting job waiting that needs a lot of power, about 80 amps. I have a lot of Astec experience and its strange that the documentation is not clear about it. Thanks in advance,
1 Related Answer
abdegh
SOURCE: I need to power up
You must tie both PSON and PSKI to GND (=5VRTN) then it works.
Posted on Sep 20, 2011
Testimonial: "Thank you,I realized that ,when I read pskill on another datasheet .now I need to raise the output voltaje a llittle any help? I found vr401 and nothi"
Astec AA23080
You have to "short" two of the sockets.
Get the CORRECT two, or else you could kill yourself, or "fry" the power-supply.
Details: http://pcsupport.about.com/od/insidethepc/a/atx-pinout-24-pin-12v-psu.htm about the "pin-out" arrangement.
It would be easier/safer to connect the sockets to a motherboard, and connect a power-switch to the ON/OFF pins on the motherboard, and then use that power-switch.
Feb 10, 2014 | Computers & Internet
ASTEC 63DV ALARM INSTALLATION MANUAL
Hi.
Would anybody have an Installation Manual for Astec alarm panel.
Feb 11, 2013 | Vehicle Parts & Accessories
Looking for schematics of ATX200-3516 ASTEC power supply. When i plug in a dc motor i have a peak of current firstly more than 6 Amps (6 amps is max rating at 12 Volts in such supply). So It shut the...
If your power supply is rated 6 AMPS and your motor is rated 14 amps peek, then when that motor starts it will draw the 14 AMPS, That will trip the power supply right then and there. After it runs a few seconds the AMPS will drop about ½ that, but still 7 AMPS is more then the power supply is rated, so you will need a different power supply.
Aug 08, 2011 | Astec (ATX200-3516) (ATX2003516) Power...
Ref ASTEC power supply from old computer model SA 147-3505 I can pick up the logic 5 volts but not the +12 volts and -12 volts .FAN not energised so I guess there needs to be an elec link via the computer...
You can jumper on an ATX power supply by using a wire to connect pin 4 (green wire) to any of the grounds on the 20 pin ATX connector. The grounds are normally a black wire. You will need to put some sort of load on the power supply such as a hard drive to keep it running.
Feb 25, 2011 | Dell PWR,SUPPLY,145 WATTS,ASTEC SA150-3411...
I am looking for a product data sheet and/or manual for the Astec SS500-3405 power supply. Might you be able to assist? Thanks,Tony.
The three I have inspected, all of them failed due to the vent. It breaks down and makes the power supply to stop.
Jan 04, 2011 | Astec Computers & Internet
My astec atx202-3515 power supply blew up. I accidently changed the watt to 115. It was 230 watts before. Will the power supply still work oe will I need to purchase a new one?
just flip it back to 115v hook it up and see if it works. if itdoesnt work replace it . I did that once it was fine the comp didnt turn on til i turned it back 115v
Mar 09, 2010 | Astec (ATX202-3555) (ATX2023555) 200-Watt...
Hello, i have a Astec 110s central vac that shut down today.
That means that either the motor or the relay is bad.
Dec 04, 2009 | Vacuums
I am looking for a manual and troubleshooting manual for a astec 73-180-0029 POWER SUPPLY
Look it up on the internet you should be able to find one. Try the www.astec.com website first.
Nov 19, 2009 | Astec Computers & Internet
Computers & Internet Logo
82 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
