Question about Cisco 7940 IP Phone
SOURCE: cisco 7940 call conferencing
No most system are maxed on the phone ... but if you had a panasonic system they are know for multi conferencing.
Posted on Apr 08, 2008
SOURCE: convert CISCO 7940 to SIP
you need different files to upload by tftp
by example version 8
P0S3-08-2-00.sb2
P0S3-08-2-00.sbn
P0S3-08-2-00.bin
P0S3-08-2-00.loads
OS79XX.TXT (tells the version)
SIPDefault.cnf
Posted on Aug 26, 2008
SOURCE: Converting Cisco 7940 IP Phone to SIP
Unlocking a Cisco 7940
Method 1:
1) Unplug the phone
2) Plug the phone back in while holding the # key
The phone will soon display “Reset key sequence detected”
3) After several lights flash press the following keys in order:
1 2 3 4 5 6 7 8 9 * 0 #
4) The phone will then ask you if you want to save the network configurations:
Save network cfg? 1=yes 2=no
5) The phone will soon display “Factory reset initiated” and will continue
through the boot up process.
If that process fails to work for some reason there
is a second method.
Method 2
Complete these steps:
The phone will now be reset.
Also see this link
http://www.cisco.com/univercd/cc/td/...tain.htm#93250
Posted on Nov 25, 2008
SOURCE: 'in call' volume cisco 7940
The handsets will eventually go bad. If it is every single handset that you have, the problem is with the system. But if the problem is only with a few of your phones, you might consider replacing the handsets. We at IdacomUSA.com have replacement Cisco handsets for sale at only $25. Hope this helps you out :)
1-800-903-9190
Posted on May 18, 2009
SOURCE: my red light wont go out on cisco 7940 phone, even
Has this just stopped working, or has it never been working?
On the call manager / CME the MWI (Message Waiting Indicator) needs to be configured. This could be undertaken either via the GUI or from the CLI
For instance ...
ephone-dn 30
number 8000...
mwi on
ephone-dn 31
number 8001...
mwi off
and also mapped to each phone to enable MWI status
ephone-dn 1 dual-line
number 111
label Chris
name fred
call-forward busy 800
call-forward noan 800 timeout 10
huntstop channel
mwi-type visual
Complete config details are at:http://www.ciscosystems.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_m1ht.html#wp1018439
If this helps pls leave feedback
Posted on Feb 04, 2010
Jan 01, 2015 | Uniden Lands Phones
May 23, 2011 | Cisco 7940 IP Phone
Sep 06, 2010 | Cisco 7940 IP Phone
Aug 25, 2010 | Cisco 7940 IP Phone
Aug 12, 2010 | Plantronics S11 Headset
Dec 09, 2009 | 3Com NBX 2102PE IP Phone
Mar 04, 2009 | Cisco 7940 IP Phone
Jan 27, 2009 | Cisco 7940 IP Phone
Apr 08, 2008 | Cisco 7940 IP Phone
Nov 27, 2007 | Cisco 7940 IP Phone
Jan 08, 2014 | Cisco 7940 IP Phone
Mar 13, 2017 | Cisco 7940 IP Phone
52 people viewed this question
