Question about GE Freezers
Why does my GE Freezer keep shutting down and keep giving codes L or a rotated F
Upright freezer, GE Model FUF21SVARWW, keeps turn off at random intervals and displays error codes L or a rotated F (rotated 180 degrees - like a 3 with the missing top line) I have pics, but not sure how to upload. The freezer only displays one character. Unplugging and replugging the freezer works, but again it will randomly shut off later and display the L or rotated F error code. Sometimes the freezer will shut off in a day, a week or even a month. Calling GE didn't help. GE support said they only had two character code errors, and had no idea what an L or F code meant. They suggested having a GE repair guy come by, but the freezer is 3 years old and we would rather just buy a new one if it is going to be several hundred dollars to repair. An appliance repair guy came by to fix something else, but he too didn't know what the freezer codes meant. It shut off during a two week vacation, and ruined a lot of food. It would be nice to be able to leave home for a weekend and not have to worry about the freezer. I appreciate any and all help.
5 Related Answers
Anonymous
  • 150 Answers
SOURCE: Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Posted on Apr 23, 2008
Anonymous
  • 93 Answers
SOURCE: Upright freezer keeps thawing & re-freezing??
check your defrost timer
Posted on Jul 18, 2008
kachbibi1
Bill Dickerson
  • 979 Answers
SOURCE: FREEZER ALARM WILL NOT SHUT OFF
You can try 2 things. Unplug it for about 2-3 minutes and then replug it. It should reset itself. You can silence the alarm or muffle it. Silencing it should be hard. Disconnect it from its source. You may want to find out why it is alarming constantly. Have you called Sears and asked them?
Posted on Feb 17, 2009
jumptrout51
steve
  • 3361 Answers
SOURCE: Frigidaire upright freezer Model #FFU17C3AW1 Not keeping cold
Yes that is the correct part number.
If a new cold control does not correct the problem. Replace the compressor start relay.
Posted on Mar 12, 2009
Maytag317
Victor
  • 1136 Answers
SOURCE: Freezer outside walls are very hot. Not maintaining temp
Hi, The walls are getting hot because that is where the condesor coils are. The condensor coils are where the heat is disperst that is trap as the coolant pumps through the evaporator coils inside. The fact that it is holding 0 degrees is a good sign. Is this freezer in a garage?
Check the door seals to make sure no heat is getting into the freezer other then when the door is opened.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jun 24, 2009
When i moved my kic chest freezer model kc0021-Aa, I heard an light explosive sound and now the freezer does not go on.
The following is the GE moving instructions. If you have started before the 24 hour rest period and the unit had been rotated from vertical have the compressor inspected.
FREEZER MOVING INSTRUCTIONS Please use the following steps when relocating an upright or chest freezer:
  1. Disconnect the power cord from the wall receptacle.
  2. Remove the food, defrost, and clean the freezer.
  3. Use blankets to protect the freezer finish from scratches.
  4. Place the freezer on its side for moving only if you have no other choice.
  5. When transporting a freezer, keep it in an upright position. If transporting it in an upright position is not possible, lay it down on the compressor side of the unit. Be careful to secure the door to prevent it from opening.
  6. If it has been transported on its side, set it right side up in its final location and allow the freezer to sit for the same amount of time that it was on its side (24 hrs max.). Do not plug the unit into the electrical receptacle without allowing this settling time. The unit can be damaged if it is plugged in prematurely.
If the unit was transported in an upright position there is no waiting time required.
Hope this helps?
Apr 07, 2017 | Freezers
GE UPRIGHT FREEZER NOT FREEZING.
Hello Mary;
My name is Peter. I am a retired field service refrigeration technician.
You are locked in the defrost mode. About every 8-10 hours your freezer will go into a defrost mode for 20-30 minutes. This is where all of the components will shut down except for the light.
You have water on the floor because your condenser fan and compressor is shut down.
You did not provide a model number. Your model number is on the inside wall of your freezer near the top. So, I can only guess.
Lets take your freezer out of the defrost mode. In the lower back on the left hand side is your defrost timer (This may also be in the lower front depending on the model). Following is a picture of what a defrost timer looks like.
The time is mounted on the back of a plate and held on with two screws. The plate has a hole through it to give you access to the round knob on the left. The knob has a slot in it. With a flat head screw driver turn the knob clockwise. You will hear a click. Turn one click at a time until the freezer turns on.
The timer cost about $20.00. You can replace it yourself. Unplug the freezer. Unscrew the timer. Remove the connector on the right.
You need to replace the timer or you will have icing problems.
Send me your model number and I will tell you what the part number is.
Feb 17, 2014 | GE 25.1 cu. ft. / 711 liter Chest Freezer...
My GE FUF14SVRWW upright freezer will shut off for no reason. The digital temperature control will be blank, the light will not turn on, and freezer isn't running. I will unplug it for a few minutes and...
Ach, digital controls! It sounds like the logic board/panel is on the fritz. No cure unless you can identify the malfunctioning component and replace it.
Nov 05, 2013 | GE FUF14SVRWW Upright Freezer
Sears Ken Elite upright freezer model no 25329082991 temp alarm
alarm should go off when freezer reaches minus 18c or lower.
Feb 05, 2010 | Freezers
Things in freezer melt and re-freeze
Your condenser fan motor at the compressor is either filthy or needing to be replaced. Air flow is pulled over compressor to keep it at a good operating temp. If the fan cannot pull air across compressor it will over heat and shut down on overload. Imagine working in yard on hot summer day and wearing a dust mask over your mouth and nose. Your body shuts down more needing more rest. Same thing with refrigerators, they have to be able to breathe properly also.
Jan 27, 2010 | GE Freezers
I want to just keep cokes,water,beer etc. in my small upright frigidaire freezer. is there a way to just make it cold enough not to freez the drinks.
Go to Home Depot find you a timer they start at $10.00, you know turn lights off/on when your not home. . They have an digital one for about $16.00 Set it up, ck your times, run it then shut it off for a while keep adjusting till you can keep the temp you want.
Apr 25, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Feb 09, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Use a freezer thermometer and tell me the actual temperature. Or at least store some ice cream and see if it stays brick hard. Unless I have some idea of the actual temp I can't tell if defective freezer or alarm
May 11, 2008 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Freezers Logo
225 people viewed this question
Top GE Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Are you a GE Freezer Expert? Answer questions, earn points and help others
