Question about Sharp MX-2700N Color Copier
How to change copy amount in counter - Sharp MX-2700N Color Copier
Posted by Shafirrahman on
san3409jl
    Habit-Forming:
  • Sharp Expert
  • 190 Answers
You can only reset copy counter only
Posted on Jun 27, 2014
When trying to print more than 10 copies at a time, error code c-2558 appears and it stop printing..means it can only print 9 or 10 copies at a time but not more than that then error code appears
Code C2558 Description Abnormally high toner density detected TCR sensor
• TC ratio in the developing unit, which is determined by toner replenishing amount control mechanism, is a predetermined value or more for a given number of times consecutively. Remedy 1 Make sure that the following counter is cleared at the developer replacing. [Service Mode] - [Counter] - [Life] - [Developer Use Time] 2 Perform image troubleshooting procedure if image density is low. 3 Reinstall developing unit. 4 Reinstall toner bottle. 5 Check the contact of developing unit for proper connection and correct as necessary. 6 Check the connector between TCRSB CN29-relay CN28-PRCB CN24 for proper connection and correct as necessary. 7 Check the connector between M3-PRCB CN8 for proper connection and correct as necessary. 8 Check the connector between M4-relay CN13-PRCB CN8 for proper connection and correct as necessary. 9 M3 operation check. 10 M4 operation check. 11 Change developing unit. 12 Change TCRSB. 13 Change PRCB.
Feb 10, 2016 | Konica Minolta "Minolta Bizhub 363 Copier,...
A smudge appears on every copy of my photocopies. Why?
please clean the glass and laser ,otherwise change the drum and blade
Mar 05, 2014 | Toshiba e-Studio 232 Black and White...
How do i set the counter papaer. I want to set the conter so I know how much paper and ink I am using
There is No way to set the copier to tell you the amount of toner & paper counter. Unless you make a copy of the same exact copy ever time you press the start button. The toner yield is figured out by 5% coverage of toner on a Letter size paper
May 21, 2012 | Canon Office Equipment & Supplies
Reset counter sharp ar-5631
Press the :
( #/P ) key --> ( * ) key --> ( clear ) key --> ( * ) key
clear the misfeed: 24 start --> 1 start
reset the maintenance counter: 24 start --> 4 start
reset the developer counter: 24 start --> 5 start
reset the copy counter: 24 start --> 6 start
reset the printer counter: 24 start --> 9 start
Nov 03, 2011 | Sharp AR-5316 Advanced Digital Imager...
MFC 8440 drum changed but still states to change drum soon. Faxes are only coming in after turning off/on machine. It indicates printing but nothing happens.
There were instructions with the new drum cartridge that explained how to reset the drum counter. If you still have the box and paperwork, then go through that step-by-step and reset the counter. The machine still thinks that it has the old drum. After a certain amount of copies or prints, the machine will save itself by turning off the printer or copy functions.
Nov 02, 2010 | Brother Office Equipment & Supplies
Need to reset the drum counter on the AL 1740 sharp while changing to a used drum
Entering in the simulation mode:press Clear - Interrupt - 0 - Interrupt -Main code - Start -Subcode - Start.
When the clear all key is pressed the simulation mode is cancelled.When the interrupt key is pressed,the proces is interrupted and the screen returns to the subcode entering display.After cancelling the simulation mode be sure to turn OFF/ON the power and check the operation.
Main code 20 subcode 1 =Maintenance counter clear.
Main code 21 subcode 1 =Maintenance cycle settimg
subcode 2 =Mini maintenance cycle setting.
Maincode 22 subcode 1 = Maintenance counter display
subcode 2=Maintenance preset value display
subcode 3=Jam memory display
subcode4=Total jam counter display
subcode 5=Total counter display
subcode 6=Developing counter display
subcode 7=Developing preset counter value display
subcode 9=Paper feed counter display
subcode 12=Drum counter display
Maincode 24 subcode 1 =Jam counter clear
subcode 2=Trouble memory clear
subcode 7=Drum counter clear
subcode 8=Copy counter clear
Maincode 26 subcode 22=Language setting
Maincode 42 subcode 1=Developing counter clear
Maincode 43 subcode 1=Fusing temperature setting
Maincode 46 subcode 1=Copy density level adjustment
subcode 19 AE mode picture quality change
Nov 20, 2009 | Sharp AL-1641CS Laser Digital Copier
E245 for ir1630
E-245 is for the defective counter pcb. the board is a small one on the main controller that keeps track of the amount of copies the machine has made. this code is normaly seen when someone changes the main board and forgets to switch the counter pcb. it is possible that there is a loose screw on the board.
Jul 31, 2009 | Canon imageRUNNER 1630 Copier
What does ce 04 00 08 mean? I can get no response from my photocopier. It is a Minlota 1030 f. There is a lot of black lines down the paper when it was working so I am wondering if it has run out of ink???...
Copy counter display or drum life counter.Not appear one mail icon and arrow down?If yes it is a mantenance time,you ll be change IU (imagine unit)or developer ,OPC drum,2 collars,cleaning blade.
May 18, 2009 | Minolta EP1030/1030F CS/PRO Copier
How to read the meter on Cannon Copier
Yes, that is the correct counter of the copier. If you are doubting it, you can look at the bottom right of that display and confirm that the serial number is the same as on the back cover of the copier and also, it well tell you the model of the copier aswell. It is kind of hard to fake the meter or change it to a lower amount. To do it you need to change 3 PCB's from another copier & it is more work to bother with.
Nov 06, 2008 | Canon NP 6050 Copier
Sharp MX-2700N Color Copier Logo
21 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
