Jenn-Air JED8430 Electric Cooktop Logo
Question about Jenn-Air JED8430 Electric Cooktop
How to replace Jenn-Air JED8430ADB Knob, Pop-up Fan
Received replacement Pop-up Fan knob for Jenn-Air but do not understand how to get it installed. Does it somehow screw down?
Posted by Glinda Irving on
2 Related Answers
Anonymous
  • 600 Answers
SOURCE: Cooktop Model, Maytag JED8430ADB. When I tried to
Hello, Thank You for using FixYa. I will be helping you today.You have to lift the unit up from the counter use some boards across the counter to support it and remove the screws from around the unit under the glass lip. On some units there are screws under the vent grille also. After removing the screws lift the whole top off.Thats all you have to do.
Thank You and please rate my answer if it was helpful..
Posted on Jun 12, 2011
James McMahon
  • 8 Answers
SOURCE: how to clean jenn air pop up fan knob?
Purchase some silicone lubricant spray (available on Amazon for $5)
Posted on Oct 19, 2012
Electric jenn air cooktop shocking me JED8430BDB
Knob is probably split/damaged and the hi voltage from igniter is running through it , remove knob inspect it and clean or replace it.
How to clean jenn air pop up fan knob?
1helpful
2answers
Cooktop Model, Maytag JED8430ADB. When I tried to replace the Fan Control Knob, I accidently pushed the Fan Switch and Knob into the compartment below. How do I get the switch & knob back?
1helpful
2answers
I have a Jenn Air radiant glass cooktop, model CCE3401B. The left rear burner will not heat. Howver the indicator light under the control knob stays on continuously, regardless of the position of the...
If the light circle around the knob stayed on, then you have the same problem I just had. I purchased a OEM replacement switch via ebay for $38. Very simple replacement, but take your time so you understand how it works. It took an hour to install and works fine now. Here is the link to the parts list:
shared.whirlpoolcorp.com/assets/pdfs/literature/Repair Part List - CCE3401B.pdf
If you can, take pictures with your phone of how everything is assembled before you take it apart. It will save you hours of aggravation.
I must say, Jenn-Aire (Whirlpool Corp) was less than helpful. I asked for some advice prior to purchasing the replacement part and all they would tell me is they were willing to schedule an authorized repair shop to come over. The closest was a 2.5 hour drive each way, and the travel time cost was $85/hour. Plus the part at list price ($90 something) and installation was going to cost $600. Give me a break.
Jenn Air cooktop JED8430ADB not heating, fan & knob lights work?
Some times a breaker can be partially tripped and not visible . You should try turning the breaker off and on several times.
always unplug electricity before attempting to repair on any electrical appliance
Problem w/ plastic knobs on JennAir electric downdraft cooktop
NO METAL KNOB FOR THAT MODEL COZ IF USE METAL EVERY TIME U USE IS HOT THATS WHY DESIGN FOR PLASTIC,MUCH BETTER TO U REMOVE THE KNOBS AFTER U TUNN ON THE HOBS TO LESS MELT THEN RETURN IT IF U TUNR IT OR ADJUST.
Blown accessory fuse? jenn air cooktop jed8430adb
the unit doesnt have any internal fuses. you have a house fuse blown or circuit breaker that tripped. the fan switch can be found online or from your local parts house and make sure you get the clips to hold it to the mounting tabs.
next time you get ready to work on it, just make sure and turn off the power first as you will touch the metal terminals to the frame again.
1helpful
Jenn Air model JED8430ADW
are you up for the job? you may need a new switch.(Part # 74009254)the origal switch is nla but this switch should work. If you attemp changing yourself make sure you turn off the circuit breaker to the range,
Top Jenn-Air Cooktops Experts
Marvin
Marvin
David Shaub
Paul Carew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
