the heater unit is the problem.
yo can get a repair kit by search on the Internet or go to Toshiba web site.
the repair kit come with instruction, if you can handle the mechanic part of things. then you are all set.
Remove the glass and thoroughly clean the lamp, mirrors and lens. Also the glass on both sides. If that does not work, remove the toner and drum, look inside the machine for a small opening about 8 inches long and a quarter inch wide. That is the laser window. It may also need cleaned. It is possible the laser needs to be removed and cleaned. I am not sure, can you print reports on the p model? If so make a printed page and tell me if they look fine. What you have to remember on a digital copier is when the optics get dirty , the image gets lighter.
This type of printing defect is normally caused by 1 of a few problems - the easier one first:
1. Toner cartridges sometimes do not have the toner evenly distributed - close the toner cartridge and inspect the hopper right below it for even distribution of toner.
The harder ones:
2. This type of defect can also be caused by dirty charging section - for the drum to pick up the toner it must be charged electrically prior to exposure - if the charge grid is not clean then it will not give the drum an even charge - not sure were this is in this printer yet - looks like it comes as part of the drum kit so this should not be causing this issue.
3. The last and most difficult to check is paper alignment with the drum - is the paper contacting the drum evenly - look for possible problems in the paper path with the drum unit removed - look for something uneven around the area were the paper contacts the drum
