Question about Samsung YP Audio Players & Recorders
My yp-u6 cannot conncet to my computer, what possible solution?
Posted by jackilyn pantanosan on
1 Related Answer
Anonymous
  • 2080 Answers
SOURCE: I need a manual for Samsung YP-U6 2GB MP3
First of all, thank you very much Val for choosing FIXYA today for your online technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://downloadcenter.samsung.com/content/UM/201009/20100927090052984/YPU6J-COMMON-ENGLISH1.0.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Posted on Jan 16, 2012
When I connect it to laptop its getting charging but it doesn't display to open???How to solve this problem????
make sure it is powerd on when connected to the pc most devices need to be on for the computer to find them
1helpful
I have a Samsung YP-U6 MP3 player which worked very well for the past 4 years. Suddenly the connection between the PC and the MP3 player didn't work any more. When I plug in the MP3 player in the USB port,...
Sandro, from what you describe, thanks for the complete story, I'm afraid the USB connector in the MP3 player is defect. Or the connection inside the player. If you tried another MP3 cable and that did not work, it must be in the player.
Be aware an USB cable has different wires for charging and for the digital connection. So a cable could be used foe charging, and still be defect for digital throughput.
Perhaps you could try to clean out the USB connector on the player, but be careful not to bend or break any pin in the connector. Is a tooth pick and if you have an air blower, blow in the connector, if you see anything like a bit of dust or a scrap of paper.
Then the opening of the player.
As a repair engineer, I would not open it, unless I had a repair manual. I never had a player like this on my bench, but I'm convinced it can be opened. But because these little devices are often glued, it could be possible you can open it, but you won't be able to put it together.
Sometimes I use the site ifixit.com but they did not (yet) open a MP3 player, so that can't help you. I tried to find a repair manual, but that failed too.
I hope you can fix it by cleaning the connector, because if not I think you have to start saving money for a new player.
Sorry
Joe.
1helpful
We are having xerox 1038 model usa made . we are getting the error u6 when we switch on our machine . so plz suggest us the best possible way to fix up the problem ...`````
U6-1 The main PWB failed checking the ROM.
Shut down and restart the copier. If it appears again U6-1, replace the main PWB.
U6-2 The main PWB failed checking the RAM.
Shut down and restart the copier. If it appears again U6-2, replace the main PWB.
U6-3 and U6-4 The main PWB failed to check the battery MNV (U6-3). Or the main PWB does not properly initialize the NVM (U6-4).
Follow the procedure in the development of memory to initialize the NVM, code 20-96. Shut down and restart the copier.
2helpful
2answers
I need a user manual for Samsung MP3 player YP U6
You can download and print the user manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Thanks for using FixYa
2answers
How do you turn it on?
Here is the MANUAL for the Samsung YP-U3 MP3 Player. This is a pdf document, so you may need to install Adobe Acrobat Reader if you don't already have it installed.
Page 14 of the manual describes the turning on/off of the player.
While looking at the front of the device, the power button is the lower button on the right side. That same button is also the Play/Pause button. Press and briefly hold the button to turn on/off the device.
Open Questions:
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
