Question about HP Officejet 6000 E609N Inkjet Printer - Color - 4800 x 1200 dpi - U
Where is the # and number 6 button located?
Wireless radio turned off. Easiest solution above but don't know where these buttons are.
Posted by Peter Donald on
ONE-Touch-Solution
  • HP Master
  • 1,679 Answers
Hi Peter,
If the printer you are using is Officejet 6000, It is single function printer and does not support Fax. This printer does not has Front panel buttons like the one you are looking for.
Regards,
Sean
Posted on Jun 03, 2014
  • 3 more comments
  • Peter Donald
    Peter Donald Jun 03, 2014
    So how does the radio signal get turned back on? Just pressing the
  • Peter Donald
    So how does the radio signal get turned back on? Just pressing the wireless button does nothing anymore and that's all the manual says to do.
  • ONE-Touch-Solution
    ONE-Touch-Solution Jun 04, 2014
    Press the Wireless button. Run the Software/driver CD that you received with the printer. If prompted during the installation, you need to connect a USB Cable from Printer to PC. Follow the instructions to setup the printer wireless.
  • Peter Donald
    Peter Donald Jun 08, 2014
    This procedure crashes the install app.
    ONE-Touch-Solution Jun 09, 2014
    Most probably, you should download the drivers from www.hp.com and try installing.
Peter Donald
    New Friend:
The number of hours spent so far trying to fix this problem
has exceeded the value of buying a new printer. So I should have done that.
Posted on Jun 08, 2014
Can anyone help me to unlock radio code on my HONDA crv2000 please
urn your ignition off to begin retrieving your radio code. Press and hold the "1" and "6" preset buttons on your radio. Turn your ignition on. Write down the code displayed on your radio. The display will flash with two numbers: one beginning with a "U" and one beginning with a "L." Write down both numbers (beginning with the "U" number), and then disregard the "U" and the "L." This number (eight digits) is your radio serial code. You'll need it to retrieve your radio anti-theft code. Contact Honda to retrieve your radio anti-theft code. You'll need your 17-digit VIN...Vehicle Identification Number, found beneath the driver's side of the windshield and your radio serial code. Honda's customer service number is (800) 999-1009. Provide the representative with the information to acquire your radio anti-theft code. You can also retrieve your radio anti-theft code online at https://radio-navicode.Honda.com/ then turn your ignition to "Acc" or "On" to power on your radio. Enter your radio anti-theft code using the preset buttons at the bottom of your radio. For example, if your anti-theft code is "55512," you would press the "5" button three times, then the "1" button, then the "2" button. This will unlock and reset your Honda radio.
you can try the above for your 2000..if you get two 4 numbers have someone write them down. then go to the web site above. you'll need the VIN too.
Unfortunately most of the time, owners of 2000 and older Honda vehicles need to physically remove the radio from the dashboard by using some automotive pry bar tools and locate the serial number sticker on the back of the unit.).
hope this helps a little
Jan 07, 2018 | Honda Cars & Trucks
Frequency for Motorola MU24CVS UHF (4 Channels) 2-Way Radio
This radio has several available frequencies built into the unit:
1 - 464.5000
2 - 464.5500
3 - 467.7625 *
4 - 467.8125 *
5 - 467.8500
6 - 467.8750
7 - 467.9000
8 - 467.9250
You would need to read out each channel to determine what each of the 4 channels is programmed to. Reading out is easy on this unit. With the radio turned off, select the channel with the channel knob, then hold in the PTT button while turning the radio on, immediately it will tell you the frequency number, (if you want to change the freq you can use the PTT button to walk your way up through the numbers to the number you'd like), then if you press the monitor button it will lock in your chosen frequency and it will tell you the private line code (if zero it is turned off), then press the monitor button again to lock everything in. Do this on each channel and you will know how your 4 channel radio is programmed.
Note: This radio is a wideband radio and only a few were produced with narrowband capability. After Jan. 2013 you are required to use narrowband only in the USA. If your MU24 radio has two RED dots above the word Spirit it is narrowband on only frequencies 3 and 4. If your radio has no red dots on the label your radio is wideband only.
Best regards.
Dec 08, 2013 | Motorola MU24CVS UHF (4 Channels) 2-Way...
How to switch on wireless connection on the msi s420
Maybe you don't have your wireless turned on. Look onboth sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can togglethe wireless on or off. Normally you would Press and Hold the FN functionkey located at the lower left of the keyboard, then hit the correct F1 thru F12key that toggles the wireless. The correct F1 thru F12 key to hit willhave the wireless signal icon )))) on it. Or it might have the icon of a towerwith the wireless signal icon )))). Normally the screen will displayWireless On or Wireless Off when you toggle the wireless.
On some computers there might be a button above the keyboard or on the sides or in front to press to start the wireless.
Jun 04, 2012 | Computers & Internet
Where do i find the wireless connection button on a vaio
Some laptops don't have wireless buttons. You toggle it by the keystrokes described above. If there is a wireless button it will be located above the keyboard, on the sides or in front of the laptop.
According to your manual, the wireless switch is on the side of the laptop. See page 15 of the manual. I have provided a link below for the manual.
http://www.docs.sony.com/release/VPCEC3_series.pdf
Jun 03, 2012 | Sony VAIO VPCEC3CFX/WI 17.3 LED Notebook -...
Where do I find the wireless button on an IBM thinkpad X31?
Some laptops don't have a wireless button or switch. If that's the case they control the wireless by keystrokes. Look onboth sides and in front for the Wireless Switch and turn it on. Look on both sides and in front for a wireless button. Look just above the keyboard for a wireless button.
Jun 01, 2012 | Computers & Internet
How do u find the button to make sure the wireless is on
Hi there!
Depend on the brand of laptops, the position of wireless button is located in different places. Most of the cases, it stays in the front or in the left side of your laptop. It will have the sign or word written to let you know which way to turn on or off the wireless adapter. There is also a wireless light to confirm that the wireless is on or off. And the Fn + Fwireless to turn the wireless adapter on or off too.
So you have : when wireless button is set to Off, whatever you do on laptop still not make the wireless working.
If wireless button is set to On, you still need to press Fn+Fwireless to turn on the wireless.
I don't know you understand or not because it quite messy explaination. I don't know why all laptops have to have 2 places to turn on and off wireless adapter. One place is enough.
Hope this will help.Thanks for reading
Jul 19, 2011 | Computers & Internet
Don't know how to save and assign radio channels
ok change the channel to what u want to listen to then hold the number 1 button for like 3 sec or 5 secs then that channel is programed to channel 1 repeat steps for button 2 3 4 5 ect... with ur other fav stations u like to listen to.. then u can press the fm button to go to fm 2 which again u can program 1 through how ever many channel numbers ur radio shows now program different stations other then the ones u just programed on fm 1 choose 5 or 6 other station the fm2 just offers u more stations to program other wise just program the normal 5 or 6 stations to ur radio
May 16, 2011 | Car Audio & Video
Just got my car fixed and my radio locked up
This is a problem with the Theft-Loc system. I believe you will have to take it to the dealer to have the radio unlocked. I found this procedure on the web, but I don't know if it will work. Good luck.
1. Turn the ignition ON (The radio should display "LOC")
2. Hold down the Radio Presets 2 and 3 buttons for six seconds
3. The radio display changes from LOC to a three-digit number. Write this number down. You now have fifteen seconds to complete the next step.
4. Press the AM/FM button
5. The radio display changes to another three-digit number. Write this number to the right of the first one.
6. You now have a six-digit number, the first three digits are from STEP 03 and the last three digits are form STEP 05
7. Call 1-800-537-5140
8. Press 1 then # (pound). You'll hear "Invalid Code, try again"
9. Press 139010 or 106010 or 206010 or 202107 then # (pound). You will be asked to enter your four or six digit code followed by *
10. Enter the number from STEP 6 then *
11. Listen to the four-digit number and write it down. It will be repeated twice
12. Turn the ignition ON (The radio displays LOC)
13. Use the MN and HR buttons to enter the code from STEP 11
14. Press the AM/FM button. The radio display changes to "SEC". Your radio is now "un-locked" and usable.
Apr 19, 2011 | 1999 Pontiac Grand Prix
1997 bonneville has LOC on the radio, How do I clear it?
if you dont have the code, the radio has to be removed and a gm dealer can get the code.
Oct 04, 2009 | 1997 Pontiac Bonneville
Car radio code
Check put the peugeot GSi 6 site.
I read there trhat the way to locate the code is;
1) pull out the radio ( I had to get the metal "keys", named sony at Halfords)
NB the slots for the 1995 306 are underneath the facia.
2) from the two numbers on the bar code...take the LAST 4 DIGITS of the BOTTOM number
3) add the following numbers in sequence to them;
a) add 1 to the first number
b) add 2 to the second number
c) add 3 to the third number
d) add 4 to the last number
IF ANY OF THE NUMBERS GO ABOVE 6 YOU MUST SUBTRACT SIX FROM IT AS THE RADIO CANNOT ACCEPT NUMBERS ABOVE 6.
To input the CODE into the radio, you need to keep pressing the number 1 button UNTIL you see the first number of your code displayed ie press it 3 times if entering the number 3 from your code.
Then use the number 2 button to enter the 2nd number of your code
Then the number 3 button to enter the 3rd number of your code
Then the number 4 button to enter the LAST number of your code.
God Bless!
Apr 20, 2008 | Car Audio & Video
HP Officejet 6000 E609N Inkjet Printer - Color - 4800 x 1200 dpi - U Logo
75 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
