Waste toner motor. Remove the Waste toner box and transfer belt ensure the waste toner box is not jammed up and check the transfer belt toner removal section is OK. Also check the gears on the left side of the waste toner box is ok and the machine gears ok not jammed. could also have a jam in the internal tube that runs the old toner to waste toner box get a tech out to check
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Have a BIZHUB 550 with a C-3724 error on it.
Fusing abnormally high temperature detection
The fuser section reached a temperature outside of safe operation. You can reset the error by: Turning the main switch off, leave the operation panel switch on, hold down the utility/counter key and turn the main switch on. As the screen loads you will see a black dot in the top right corner, at this point you can release the utility/counter key. The machine will take a minute to load. When the screen loads you will have a key that says "Trouble Reset" press it and you will get a "OK" message. Turn the main power off for 10 seconds and turn back on. If message returns you must replace the fuser. Attempt Trouble reset again at your own risk!! Fusers are a Fire Hazard
