The door latch is striking the lock entrance too low. How do I adjust the latch or door to realign the latch?
Good Afternoon Mjiuliano,
I understand that you are looking for instructions on how to align the door on your Electrolux washer, model# EIFLS55IIW. Typically, this is not a do it yourself fix, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your particular washer and should be able to realign the door with ease. Hope this is helpful.
-Best Regards-
WP
Posted on Jun 02, 2014
If the door won't latch, the latch assembly might be defective. Inspect the latch assembly to see if it is cracked or worn out. The latch assembly is normally replaced all as one part.
Enter your model number to see parts for your dishwasher.
If the door won't latch, one or more of the door hinges might be bent or broken. If the door hinges are not working properly the door won't close squarely and then the door won't latch.
If the door won't latch, the door catch might be out of alignment or broken. If it appears to be OK, reposition it as needed. If appears broken it should be replaced.
If the door won't latch, the door lock assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door lock is broken, replace it.
If the door won't latch, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
If the door won't latch, the door strike might be defective. These are normally made of plastic or metal and cannot be repaired. If the door won't latch and the door strike is broken, replace it.
