Question about Canon I-Sensys Mf4550d All-In-One Laser Printer Print, Copy And Scan
How to reset the fuser on Canon mf4550 - Canon I-Sensys Mf4550d All-In-One Laser Printer Print, Copy And Scan
    Master:
  • 1,004 Answers
Reset it how? If it is the page count, you can do that in the service menu. Generally, they do this for a reason and youcought to replacecthecfuser if it says you should!
Posted on May 29, 2014
Anonymous
SOURCE:
Want to correct a system error E000 on canon IR1600 photocopier
E000 indicates a low temperature problem in the fuser unit.
  • Check the fuser for any jammed paper and remove it
Check and replace with spare part if needed:
  • the thermo lamp,
  • the thermistor in the fuser unit
A code reset is needed:
  1. Press ADDITIONAL FUNCTIONS, #
  2. Go to #7 PRINTER, press OK
  3. Go to #4 PRINTER RESET, press OK
  4. YES = (*)
  5. Power cycle the unit.
Jan 05, 2011 | Canon iR1600-2000 PS
Error e000004-0010 how to solve
I'm not a Canon Copier Tec but I know E04's on Canons generally means heat/fuser error - ie fuser, usally fuser lamp, thermister or thermal fuse. Have fuser replaced.
Have it looked at, due to it requiring electrical knowledge, ie test heater lamp(open), thermal fuse(open), thermister(check for toner built up on face) with the user removed from printer (fuser=hot bit that paper goes threw, just before where paper exits to go to sorter) or just replace assem.
There maybe a reset required, on some canon models after problem has been fixed.
So here is a link with explaination of the reset on a canon model simular to yours http://www.copytechnet.com/forums/canon/2673-error-code-e004-canon-np-6330-a.html
pls vote me to keep us alive
Nov 17, 2010 | Office Equipment & Supplies
Canon D340 Copier System Error E000
Your printer show Error code E000 suggests the problem history has recognized all of these of the following error codes four moments: Error code E001;Code E002;Error E003. Printer Canon E000 error will be removed in the service mode.
Please try reset factory your canon printer..but if it still show error code E000 again ,you can try with a genuine fuser unit (reseting fuser unit). Good luck
Solution 3: Try this, atempt will clear canon E000 code in Service mode:
1.Press ADDITIONAL FUNCTIONS, #
2.Go to #7 Printer and Press OK
3.Go to #4 Printer Reset and Press OK
4.Yes = ( * )
Sep 09, 2010 | Canon PC-D340 All-In-One Laser Printer
What is error code E000 mean
Solution:
Press "Additional Functions",
Press "#", then press the "Right Arrow" button till it says, "Printer",
Then press "Set" then press the "Right Arrow" button again until it says "Printer Reset"
Then press "Set" again, the display will ask you "Yes" or "No".
Press the "Left" arrow for "Yes", then press "Set".
Now, unplug the power cord and wait 5 seconds and plug back in.
If this don't work, get a new fuser.
Feb 04, 2010 | Canon imageCLASS D880 All-In-One Laser...
Canon super g3 image class d880
E000 means your fuser section is having problems.sometimes you can reset but may need to replace fuser unit.
Sep 04, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
How to reset error code E000 on IR2000
E000: Fuser did not heat up. check Fuser lamp, check thermistor, check thermostat, if this parts ok try to reset the trouble code. to reset fuser errors, first shut power off and turn on again. Then, go to service mode. Select "User mode" by pressing additional function ( * ) key then Press "ID" key ( # ) on user mode screen. Select menu 7 using cursor key. Press "OK" key. Select 4 item with cursor key. Press "OK" key. Printer reset. YES=( * ) to clear fuser error code E000.
Jul 11, 2008 | Canon Office Equipment & Supplies
E000004-0010
canon NP 6330
error 800
Nov 15, 2007 | Canon imageRUNNER 5570 Copier
Canon I-Sensys Mf4550d All-In-One Laser Printer Print, Copy And Scan Logo
196 people viewed this question
old marine
old marine
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
