Kenmore 98702 Stacked Washer/Dryer Logo
A
Anonymous Posted on May 29, 2014
My kenmore 98702 stacked washer/dryer washer lid does not stay open
James Hope
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 06, 2014
James Hope
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
78
Points
This isn't a solution but i took the cover behind the lid off to acces the vent and never put it back,it gives you another 3/8" for the lid to lay back.
djames64
Level 1:
  • Contributor 3 Answers
  • Posted on May 29, 2014
djames64
Contributor
Level 1:
Answers
Questions
0
Helped
4189
Points
6
Underneath the top unit (the dryer) there should be a spring loaded catch that holds the door open. See if it is gummed up and stuck or possibly broken off.
5 Related Answers
Anonymous
  • 623 Answers
  • Posted on Aug 12, 2008
SOURCE: dryer door
I would try to run the dryer again. If that doesn't work, it's time to call the repairman.
Anonymous
  • 1214 Answers
  • Posted on Jan 22, 2009
SOURCE: Kenmore 98702 Stacked Washer / Dryer WON'T DRAIN
Did the unit ever drain? If it did, has anything changed?
Make sure the drain hose in back has not pinched (unit slid backward against the wall, pinching the hose.).
Motor is two speed, and if it's not kicking to the high speed, then there may be a timer problem.
Anonymous
  • 3361 Answers
  • Posted on Mar 08, 2009
SOURCE: Kenmore 98702 Stacked Washer/Dryer. Dryer making clicking noise
There may be coins stuck inside the tumbling vanes in the drum.
Anonymous
  • 15935 Answers
  • Posted on Sep 10, 2010
SOURCE: Kenmore 98702 Stacked Washer/Dryer Combo Model 417.98702890
There is an EXTERNAL fuse on the back of the unit.
Service manual is inside the machine's shell in plastic.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Anonymous
  • 15935 Answers
  • Posted on Sep 30, 2010
SOURCE: Kenmore 98702 Stacked Washer / Dryer - washer not
It appears your pump has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
2answers
Kenmore model 98702
No - it is one body. it cannot be replaced - only repaired.
Dryer door
2answers
Kenmore stack washer/dryer model#11098752790
Check your lid switch ,if its not engaging replace it.
Alexander
vince
