Question about Sharp AR-5316 Advanced Digital Imager Copier
Fix catridge error
I change recently catridge of Sharp mf420u but it show error on screen: CHANGE CARTIDG.how can i fix it?
Gift Ntwana
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
Enter sim 16
Posted on Apr 21, 2016
1 Related Answer
Anonymous
  • 148 Answers
SOURCE: fix u2 error for sharp AR-163
http://www.fixya.com/support/t3244018-sharp_ar_163_copier_flashs_u2_40
Posted on Mar 12, 2010
After replacing the toner catridge in Sharp MX-B200 the toner lit light keep showing, how do i remove the showing lit light
The toner light is in the shape of a triangle. If your light is in the shape of a circle you need a developer change. Technician required to do this.
Aug 13, 2017 | Sharp Office Equipment & Supplies
How can i fix error u2
Enter sim 14 if it'll not help change toner catridge
Mar 31, 2015 | Sharp AR 163 Copier
Catridge of Sharp mf420u
When the toner supply not attached the properly than comes this problem.
Better way you open the toner and check all toner supply gear ,if gear is jam than you should replace the toner.I think your toner chip version problem or destination problem.
May 29, 2014 | Sharp AR-5316 Advanced Digital Imager...
How to fix Sharp Copier AR-5731 Error code
good day, my Sharp AR 5731 showing the message Call for Service . Code : H4-00 can you help me to fixed my problem. thanks and God Bless
Mar 11, 2013 | Sharp AR-BC260 Color Copier
My Sharp Copier Model AR-M160 showing f2 error even I replace the new tonner.
Below are the F2 errors and causes for Sharp AR-M160
"F2-31" Image density sensor fault
"F2-32" Drum mark sensor fault
"F2-33" Grid voltage correction problem
"F2-35" Grid voltage correction problem
"F2-37" Drum mark sensor fault
Cause : CRUM chip defect OR Improper developing unit
Check and remedy : As you have already replaced the tonner, we can suggest Replace the CRUM chip,Replace the developing unit
Regards,
Shrey
Jun 01, 2011 | Sharp AR-M160 Laser Printer
What is error F2 in sharp copier machine?
F2 in sharp means, aproblem related to toner supply make sure the proper catridge is inserted, check with another toner catridge to make it clear that crum on the toner catridge is still good, then if the problem again continues you try to change the developer, next is ATC sensor and the next is developer unit if you have any queries feel free to contact me and rate me
May 03, 2011 | Sharp SF 2540 Copier
My copier machine sharp AR5316E shows error message 2U, please what is the solution?
remove the catridge to the machine and then insert it back. if it still display the same information the catridge might be damaged need to be replaced.
Feb 07, 2011 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
23 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
