Question about Toshiba 36A50 36" TV
What are tv codes for westinghouse led hdtv on twc remote?
How do I reset my tv or set it up
Westinghouse 40 Lcd Manual - Heroku
gfdc.herokuapp.com/Westinghouse-40-Lcd-Manual.doc
Westinghouse 40 Lcd Manual - gfdc.herokuapp.com ... led 1080p hdtv - westinghouse 40 class 39 5 diag led 1080p hdtv black model dwm40f1y1 c ... lcd hdtv - buy westinghouse uw40t3pw 40 1080p 120hz lcd hdtv led lcd tvs amazon ... 1080p hdtv dvd combo user s manual vk 40f580d tv dvd combo pdf manual download, ...
Sep 17, 2016 | Westinghouse 40" Class LED 1080p HDTV...
LD-2240 problem while trying to set up monitor all I get is no signal to any menu
Search Results
    Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240
    www.amazon.com/...1080p...LD2240/.../B007ATHRJ...
    Amazon.com, Inc.
    Rating: 2.9 - ‎21 reviews
    Amazon.com: Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240: Electronics. ...When I set it up I was disappointed with the sound but not surprised, it is a cheap TV... Apparently this is not an unusual problem for Westinghouse. ... Oh well, I tried. ...VideoSecu Articulating Arm TV LCD Monitor Wall Mount, Full Motion Tilt ...
    Amazon.com, Inc.Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240 ... When I first hooked it up to my cable connection, through the coax connector (TV ... When using as a computer screenthere's an auto adjust and full manual control .... have endured compromised sound and picture, but I've never had this problem. .... Oh well, I tried.
Jan 11, 2016 | Westinghouse 22" Class LED 1080p 60Hz HDTV...
How to program septre tv volume to twc remote. Twc said code 276, but didn't work
You may have to try another programmable remote to search for and find a code that will control your Sceptre TV.
Dec 13, 2014 | Televison & Video
Trying to find a remote code. The tv is a 19"PLEDV1945A-B and the remote is a Time Warner UR5U-8780L-TWC
TV Instructions:
TV Codes: try 333
or 116, 143, 258, 363
STEP 1 Turn on the TV.
STEP 2 Press the [TV] button and the [OK/SEL] button simultaneously for three seconds. The TV Device LED will turn on indicating that the remote is in the programming mode. The LED will remain on for 30 seconds and the next step must be entered while the LED is on.
STEP 3 Point the remote control toward the TV and enter the three-digit code number assigned to your brand device (codes can be found in the code tables in the user guide or online). If there are more than one three-digit number listed for your brand, try one code number at a time until your TV turns off.
Note: When the TV turns off you can verify that you have selected the correct code by pressing the [POWER] button. The TV should turn back on. Then try all of the functions on the remote control (i.e. volume, mute, etc.) to ensure you have the correct code. If any of the functions do not operate as they should, repeat the instructions from STEP 3 above using the next three digit code number from the brand list.
STEP 4 Store the three-digit code by pressing the [TV] button once again. The TV Device LED will blink twice to confirm that the TV code has been stored.
Program My Remote Time Warner Cable
Nov 13, 2014 | Proscan 19 In. 720p LED HDTV/DVD Combo...
Westinghouse codes
I just bought a 40" Westinghouse at BestBuy and had the same problem. My TWC remote still had the code from my old analog Samsung. Fortunately I kept the code sheet from Time Warner and using the 3 digit method reprogrammed it. Westinghouse uses 4 dif codes on their LED-LCDs. Here are the 3 digit code nos. 076 276 435 001. I ran thru the first 3 and mine was 001. Whoever your provider is use their remote to do this and not the one that came with your set. I used that remote to make all the adjustments on my set to fine tune it, color, sound, etc.following the menu. Hope this helps.
Aug 18, 2014 | Westinghouse Electric LD-3255VX 32 in. TV
Problem: Westinghouse SK-32H240S HDTV has a flashing/blinking blue/red power led
hi when the colours flash again, press the menu button on the remote control and retune the tv hope it helps
regards
shaun
Mar 28, 2014 | Westinghouse SK-32H240S Television
Need code for westighouse ld2240 serial 6616121805787
Just guessing you want to control your Westinghouse TV with some kind of remote, perhaps a programmable one. The codes are sent from the remote to the TV, therefore we need to know what brand of remote you want to use
Jan 17, 2013 | Westinghouse NEW 22" Class / LED / 1080p /...
Westinghouse - 60" Class / 1080p / 120Hz / LCD
There is a method called a Power Scan this method allows you to search for all possible codes. Try this until you reach a code that carries all of the functions desired. If the TV mode button starts flashing rapidly during this process you have exhausted all possible codes.
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network
Customer Service
Apr 17, 2011 | Westinghouse 16093 Remote Control
Codes for living solutions remote + westinghouse lcd tv
The codes for your Jumbo Universal Remote to control a Westinghouse television are 097, 100, 130, and 155.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
I hope that helps.
Oct 10, 2009 | Innovage Jumbo Remote Control
Toshiba 36A50 36" TV Logo
111 people viewed this question
Top Toshiba Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
