Question about Xante Ilumina Digital Color Press Printer
Xante illumina - getting a non paper sensor error. Is there a way to clear or reset the printer, or is there a part that needs to be replaced?
5 Related Answers
Anonymous
SOURCE: Front Paper Jam
I'm not 100% sure that this will work. I have a 3N, when we first got it I had the same problem. After clearing the jam - You have to open the top portion of the printer. Even if the jam is no where around that area... the printer won't reset itself until you lift that top piece. I even tried to turn it off, thinking it would reset...it didn't.
I know the 4g is much newer then mine...but being it's the same company.. this problem might be fixed the same way.
Good Luck.
Posted on Feb 12, 2008
Anonymous
  • 24 Answers
SOURCE: Xante Illumina runs very slow when printing on
you need to check your settings, you may need to fool the machine..
on the webpage, or the front panel, select material type as plain.
set the weight setting as auto.
in the driver, make sure the setting is set to "printer Setting"
also in the driver check the selection for "black" instead of "colour"
hope this helps..
Posted on Mar 13, 2009
Anonymous
SOURCE: What is wrong with this Illumina???
Did you ever get your problem resolved. Having same problem here.
Posted on Feb 12, 2010
tech4allmen
rey francis basa
  • 666 Answers
SOURCE: what does OPC stand for
It stands for Organic Photo Conductor or also known as Laser Drum.
Thank you for visiting FixYa! We answer your concerns promptly for FREE. Please spare a few seconds to click on YES button in return. Have a good one!
Posted on Jul 11, 2011
richardthelh
Richard Radtke
  • 3 Answers
SOURCE: How do I print sequential numbers on xante
I have a xante ilumnia and use a program called numberpress to do seq. ncr forms, raffle tickets, well really any thing that needs numbers, It works great and is easy to use, their support is great.
Posted on May 10, 2012
Full stack error
Dear your Xante printer asking to you your printer tray is full of printed papers please clear it,also checked output tray sensors carefully,hope you understand.
thanks.
Feb 26, 2014 | Xante Office Equipment & Supplies
Front paper jam xante 3g
Dear you printer paper pickup sensor stuck,please removed all papers in tray and manual feed after that restart the printer,also clear the paper path,hope you understand.
thanks
Feb 19, 2014 | Xante Accel-a-Writer Laser Printer
How do I print sequential numbers on xante Illumina
Oct 11, 2011 | Xante Ilumina Digital Color Press Printer
What does OPC stand for on the xante illumina press? I am getting a message saying the OPC is near end of life.
Jul 11, 2011 | Xante Ilumina Digital Color Press Printer
Xante Illumina runs very slow when printing on carbonless paper even for just black type. Could this be a sensor problem??
hope this helps..
Mar 04, 2009 | Xante Ilumina Digital Color Press Printer
I have been running this machine for 2 years. The only way I can run is too 1 printer media to plan - on Ilumina display panel 2 media weight to auto on Ilumina display panel - 3 When printing in printer dialog be sure set these options -  -printer features-insert option - set media type to Printer Setting
I have tried changing the media types as well and will not work for me- but setting to auto works. http://www.inkcoverage.com
Oct 14, 2008 | Xante Ilumina Digital Color Press Printer
Paper Jam will not clear
  1. I have identical problem with the Xante 1200.
Mar 14, 2008 | Xante AW 1200 Laser Printer
Xante cl30 color laser printer paper jam
Remove the fuser and examine it closely (Note: the fuser gets extremely hot. Wait until it has cooled completely before touching it!) Paper or a paper fragment might be balled up inside it.
Even just re-seating the fuser might clear the sensor that is reporting this jam.
If the printer continues to stall with this error code, even though there is no jam, it could have a faulty sensor. This would have to be repaired with a service call...
Mar 06, 2008 | Xante CL30 HSE Laser Printer
102 people viewed this question
Top Xante Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
