Question about Epson RX620 All-In-One InkJet Photo Printer
How to solve pw detector error in epson stylus px 660
5 Related Answers
Anonymous
  • 88 Answers
SOURCE: software for epson stylus color 660 printer
Try this link: http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=14423
Posted on Jun 25, 2009
Fred Yearian
  • 5603 Answers
SOURCE: i have a epson stylus 660 i am trying to print
A full cleaning of the head requires removal from the printer. The "cleaning funtion" will still leave dribbles on the bottom of the head which cause streaks. SOMETIMES you can wet a couple thicknesses of paper and drag under the heads to clean the area. Use 91% isoprophyl alcohol.
If the ink has bled out of the heads it takes a lot of patience to get the ink cleaned out. Also the paper rollers often need cleaning.
Posted on Sep 22, 2009
websnail
Martin Smallridge
  • 419 Answers
SOURCE: My Epson stylus photo RX585 tells me to switch it
This is a general error and usually it means that something serious enough to stop the printhead, paper feed or similar has happened.
Most of the time it's related to the printhead so here's a few things to check:
  1. Is the printhead able to move freely back and forth
  2. Is there anything blocking the printheads path, such as bits of ripped paper, etc...
  3. Are there any loose wires, cables, etc... that look out of place
  4. Is there ink splatter covering any plastic parts, or the strip that runs at the back of the printer? (more than normal)
  5. Is the printhead able to return to its normal parking position or is it being blocked by something.
  6. Are the cartridges inserted properly
  7. Have the chips on the cartridge(s) been soiled with ink or fallen off/out of position?
  8. Are the little wires that are located to connect to the cartridge chips, bent out of shape, or similar? (You need to look in the front/inside of the printer to check this).
Usually when you start applying these sorts of questions you identify a problem such as:
  • something that's jamming the printhead at a specific point
  • a wire has come loose
  • the parking pad has come out of its holder
  • ink has soiled a critical part like the calibration strip, cartridge chips, etc...
  • cartridge chip(s) has/have been damaged
  • the wires that provide the connection with the cartridge chip have been bent, broken or damaged.
Obviously that's a pretty long list of possible problems but hopefully it will at least narrow down what is going on in the printer so you can provide more information as to what it isn't or might be.
Hope that helps.
Posted on Oct 01, 2009
Testimonial: "Thanks for your reply, I'd already checked some of the things you mention but not all. Printer has now been replaced under guarantee."
Anonymous
  • 787 Answers
SOURCE: GENERAL ERROR IN EPSON STYLUS T10
Probably the waste ink tank is full.Try to do this:
First of all download http://www.mediafire.com/?hzxbdhkzxv9.Extract to your C drive. Run indoreset.bat, then follow the instructions.
After that right click AdjProg and select properties. Go to compatibility and select Windows XP.
Click OK at the bottom then right Click AdjProg and select run as administrator (if you have this
option). When working accept the agreement and go to
1. Particular adjustment mode,
2. Then waste ink pad counter,
3. Click Check
4. Tick both boxes.
5. Then initialization.
6. Then it's done.
Posted on Oct 16, 2009
andreask22
SOURCE: epson stylus cx4100 error and all LED's blinking
error and all LED's are blinking
Posted on Aug 16, 2011
Reset software for epson px 660
you need to buy the epson certified cartridges,they are the only ones that can be refilled,it is not software,it is a diode on the cartridge
May 29, 2015 | Epson Stylus Photo Px660
Resetting epson stylus photo px 660 using ssc utility
I don't understand. What is your question? The utility should be self explanatory. Is there some step you don't understand? If you can't reset the printer with the utility, there is something else going on.
Feb 28, 2015 | Epson Stylus Photo Px660
I have an Epson stylus photo PX 660,which is displays an error message that,paper jam inside and in real sense there is no any paper jam inside.show me how i can solve this problem.
Check the rollers (the inlet and outlet for the paper) and blow them out with a blower,vacuum, or a can of air. That should "fixya" right up. Lmk if it doesn't and I'll get down to specifics with more info from you as well
Feb 12, 2015 | Epson Stylus Photo Px660
My epson l800 write ,general error, open the printer cover and remove any paper inside the printer .turn the printer off and delete all print jobs ,turn the printer back on.am already try all but still...
Fix Epson Stylus Photo 6 Colors Printer General Error Problem
? 1:02
https://www.youtube.com/watch?v=Ci9MWG7zAkM
Dec 1, 2013 - Uploaded by TechRePair
Fix Epson Stylus Photo 6 Colors Printer General Error Problem. TechRePair ... ???????? Epson L800, T50, P50, R290, R295. User dismantling ...Missing: write
Epson General Error Problem + EPSON Adjustment ...
? 5:05
https://www.youtube.com/watch?v=gaKeB5JJqRc
Sep 28, 2014 - Uploaded by Gigi service
Epson General Error Problem + EPSON Adjustment Program / Waste Ink ... Reset Geral na Epson T30, T33, T50, T1110, L800, XP214, TX133 e ...Missing: write
epson l800 general error ' Error Help
Feb 10, 2015 | Epson L800 - printer - color - ink-jet
Epson Stylus Photo 1390 Paper Jam
It PW sensor error. For "Normal Quality" mode, the PW sensor will not work for "reading" paper existence, but for "Fine", photo and best photo it work. PW is paper widht. Small sensor at bottom side of carriage, near the head. Dirty or short circuit may be.... Can you fix it?
Jan 13, 2013 | Epson Stylus 1400 InkJet Photo Printer
Waste ink pipe for px660
This guide shows how to access the waste tube...
http://www.octoink.co.uk/kb/questions/90
It does consists of a mashup of photos from other models, but overall the approach required is covered.
Dec 03, 2012 | Epson Stylus Photo Px660
Epson Stylus color 660 - all lights (red and green) are flashing. The printer is not responding to any command or button pressing other than switching on or off. There no visible obstructions in the paper...
Q: Why are all the lights on the printer flashing? A: When all the lights flash, your printer may have an internal error. Verify that all packing material has been removed. Instructions for removing the packing material will be found on a notice in the box. If the printer has not made any noises for more than five minutes, turn off the printer. Open the cover and check for any obstructions. Power on the printer to see if the error still occurs. If the unit still gives an error, please contact the Epson Connection for further assistance.
Oct 28, 2010 | Epson Stylus Color 660 InkJet Printer
Epson RX620 All-In-One InkJet Photo Printer Logo
188 people viewed this question
Top Epson Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
